So I have a 63 inch plasma with the model number in the title and the other day while watching TV I heard a few clicks and the TV shut off. I tried to turn it on but it wouldn't respond to the remote or the power button (red light flashes on TV normally when button is pressed on remote or TV).
I unplugged it and plugged it back in and it clicks a few times then the standby mode light stays on but once again it is unresponsive to any buttons.
So I opened it up and first thing I did was tested the fuses on the power supply. 2 of the 3 were good (marked green in the picture) and 1 was blown. I replaced the blown one (marked in red) and it blew as soon as I plugged it in.
So I tested the diode next to it (marked green) in circuit using the diode test mode and it looked good (open line way way and 0.556V the other way).
Then I tested the 3 FETs in circuit on the heat sink. 2 of them (marked yellow) read as shorts all ways. And one reads good (marked green).
Do you think it's just the 2 FETs that are bad? Or could it be more? Could it be that the transformers (marked with white question marks) knocked out these FETs?im just really confused as to where to go from here. I don't want to replace the FETs and fuse only to plug it in and have everything wiped out again.
Any input here would be appreciated.
yompi
yompi
