Sony KLV 22bx310 blinking
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    all i just received sony tv . when i power the tv it will display sony logo 3 times on screen, then start flashing red light 6 times
    anyone with solution
    hispeck
  • mauda
    Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
    by mauda
    I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
    Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
    05-21-2023, 11:56 PM
  • YasaCh
    Sony kdl 40p5500 red light keeps blinking 3 times
    by YasaCh
    Hello...
    my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
    i opened the back cover no sign of damage on the powery suply or motherboard
    when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
    another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
    07-07-2025, 11:53 AM
  • stav242
    Sony KD-55X8509C white flashing/pulsing LED
    by stav242
    I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
    On inspection, there was no physical issues.
    I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
    - this seems to indicate repairing required, done by Firmware update.
    so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
    Inserted the drive and repowered the TV.
    LED changed to white flashing/pulsing ... and it sat there for over an hour.
    i was unsure what was happening so repowered the TV and now it just...
    01-08-2024, 07:39 AM
  • shahnld
    Sony kdl 65xg9505 green amber blinking
    by shahnld
    Good Day.
    I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
    i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
    green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
    01-03-2024, 03:05 PM
  • sigmeyer
    Sony KDL-32R410B Shows up logo , then blinking red light
    by sigmeyer
    Okay ,so i got this TV , immediately assuming that there is a problem with power supply ... Tried another power brick with 19v and 20V (TV is rated at 19.5v) Still nothing. Replaced All 3 caps inside the TV. Under 1 cap i found some type of liquid ... It resembled water more than anything. I see no green on inside or anything like that , Might be a fresh spill of water but im not sure.
    Anyways i replaced all caps , tried different psu's and still nothing. Is it a software problem maybe?
    Also , the exact thing that happens when turned on is this>
    I press power button ,...
    09-30-2020, 08:47 AM
