LG 42lb5820 Won't Turn On with 3 Blinking Red Light
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: LG 42lb5820 Won't Turn On with 3 Blinking Red Light
    That's the problem with replacing leds. You try to match them as best you can for colour temperature and brightness but until they are installed you cannot really tell.
    Getting hold of a replacement led strip for that set and using the leds from it to replace your faulty ones would be one way to match them. Or contact Flocko on this site and see if he can help you.
    • vinceroger69
      • Mar 2012
      • 6714
      im not sure where you got your replacement leds from but i see shopjimmy sell lg led kits 12 with diffusers at a good price they maybe a better light/colour match.
      • Wildwind
        • May 2012
        • 31
        Thanks for all the replies. ShopJimmy did not have the strips for this model in stock (for quite a while now). Even the old LEDs (less bright) still had some non-uniformity when I looked closely so it is a bad design from LG then
        Have any of you come across an LED LCD panel with a reflector film between the diffuser and LCD panel (as some models on YouTube did not have it)?
        • Wildwind
          • May 2012
          • 31
          I got some Innotek LEDs from China (which looked very similar to the original ones) and installed them individually (using SMD heatflow workstation) and glued the lens back on using superglue as I had a bit of spare time to play around with it .
            Make sure to turn down the Backlights level to as low as you can so the LEDs will run cooler.
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              this is the kit i saw as they are for lg sets the colour match maybe better?
              https://www.shopjimmy.com/replacemen...-set-of-12.htm
              • Wildwind
                • May 2012
                • 31
                This the the strips for my model but there are out of stock. They are 6V, 200mA LEDs
                http://www.shopjimmy.com/lg-6916l-17...s-8-strips.htm
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  which 6v eds did you choose from china? i dont think any of us have tried the 6v versions yet
                  • Wildwind
                    • May 2012
                    • 31
                    I bought these 6V LEDs from AliExpress. I think all sellers are selling the same LG Innotek LATWT391RZLZK LEDs. Some how these ones are a bit brighter then the original LEDs.
                    Does anyone have the datasheet for the LG Innotek 3535 6V LEDs?
                    https://www.aliexpress.com/item/LG-I...608.0.0.PNnvfE
                    The measured LED backlight voltage was 211V which is a bit higher than 192V (6Vx32LEDs). Power supply board says 208V with 235mA.
                    I might experiment and try to drop the voltage down by 10-15V and see what happens. Does anyone have any suggestions on the best way to reduce the backlight voltage by 10-15V apart from using a 10W light bulb?
                    I hate working with lead-free stuff - to hot to my liking
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      maybe a resistor across the new leds somehow to drop the voltage/brightness ? as dropping the voltage on the whole strip wont the new leds still be brighter? im still learning myself maybe budm will have a idea too try out.
                      • Wildwind
                        • May 2012
                        • 31
                        It is a stupid back-light design to connect ALL the LEDs in series (like the Christmas decorative lights) so if 1 fails (open circuit) then the whole thing is dead. Putting a resistor in across the LEDs will work but it is too tedious. If I have to open it up again then I might as well replace them with the correct LEDs
                          Disregard, double post.
                            Are you measuring the 211V with ref to GND, if that is the case you are not reading the total Vf of the LED string. LED is current device, you drop the current through the LED to reduce the brightness, the power supply is the constant current source that will try to maintain constant current through the load, sot eh the load resistance change the the supply Voltage to the load will also change to maintain constant current through the load.
                            To read the total Vf of the LED string, you need to measure the Voltage between the Anode and the Cathode of the LED string.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #34
                              i totally agree its getting the correct lg leds/colour match thats going too be hard unless you can find a cracked screen set with same model number or maybe one good led strip and swop leds over etc but means stripping it down again.
                              • Wildwind
                                • May 2012
                                • 31
                                I measure the Vf of the LED circuit and its was constant at 127V with various backlight settings.
                                I think I live with it and will wait for some cheap 2nd hand strips to come up for sale
                                  127V Vf? But you said have 32 LEDs (6V Dual-LED), Is that correct? When you vary the backlight level, the current is changed and will be regulated to that setting, the Vf will change a little, but the Vdrops on the PWM Controlled will go up when Backlights is set to less, opposite when Backligts is set t higher level.
                                  • Wildwind
                                    • May 2012
                                    • 31
                                    Yep, 127V in VDC meter reading. It could be the PWM causing the multimeter to read such low value.
                                    Could there be something wrong with the power supply board?
                                    I gave attached a photo of the backlight distortion. You can still make out the distortion with the original LEDs as well. This project has taught me quite a lot about LED CD TVs (with a lot of the forum posters' help)
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #38
                                      does the lg logo on the lcd screen look bad too? in the picture it dosnt look very clear looks like it has lines etc.
                                      • Wildwind
                                        • May 2012
                                        • 31
                                        No, picture is clear and it's a spinning logo and the camera had trouble in low light with the shutter speed.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #40
                                          Thats ok then but yes the new leds certainly are brighter i wonder if its worth you emailing shopjimmy and see if they do the lg 6v version replacement led kits as hopefully they would of tested them and be the correct colour/brightness.
                                          can you read any of the numbers etc from the bottom of the old led if it has any printed on it
                                          • jxrepman
                                            Asus X453MA won't turn on and green led light blinking
                                            by jxrepman
                                            Hi there,
                                            I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                            I have checked the charger and it is giving 19+ V
                                            I have disconnected the battery and pressed power button for 30 seconds.
                                            I tried another RAM stick.
                                            Tried disconnecting the keyboard and touchpad.
                                            Tried disconnecting the HDD and the wifi adapter.
                                            The problem persists.
                                            Hope you could help me out on this one. Thank you.
                                            12-14-2024, 06:40 AM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
