BlueDiamond Model:BD32LCDS. Blown component (Identify)
  • techfixit
    • Feb 2014
    • 44
    • Ireland
    I have a 32" BlueDiamond TV which won't power on. I removed the power board and identified a blown component but i'm unsure of the part name/number and whether or not i should test/replace anything else on the board in relation to it. I've attached pics of the board. Any help greatly appreciated
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: BlueDiamond Model:BD32LCDS. Blown component (Identify)
    I think it's a CR6224T
    https://cdn.badcaps-static.com/pdfs/...c172af165b.pdf
    https://translate.google.co.uk/trans...ml&prev=search
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      5v stby Ic failed, its a CR6224T remove it and test all related 5vstby components for shorts or open circuits.
      • techfixit
        • Feb 2014
        • 44
        • Ireland
        Thanks guys!! Any links to where i could purchase one of those preferably in Ireland or the UK? I've only been able to locate them in china
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Tbh it might be easier and just as cheap to replace the whole board, you can use any universal 3.3-24v output Tv psu.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            3.3, 5, 12, 24V supply--from any of those cheapo 32" Chinese crappolas will do for that!
            TELEFIX
            • techfixit
              • Feb 2014
              • 44
              • Ireland
              So still have this in my spare room just sitting there taking up space. Anyone care to link me to a cheap complete replacement power board on ebay or amazon? TIA
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Just fine an Leke or Megmeet psu for 32" which has the same board mounts will work.
                • cmlewis89
                  LG 47LB5DF blown power supply board
                  by cmlewis89
                  Hi folks,
                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                  09-03-2024, 07:50 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • k-krzych
                  Identify board to board connector
                  by k-krzych
                  Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
                  07-08-2025, 12:32 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
