LG 50PK950-UA Flashing Screen.
  • kitra
    • Oct 2016
    I just acquired on 50PK950 Plasma TV. The set failed with a very unusual problem. The screen flashes on and off about 74 times a minute. The brief lit screen shows a good picture and sound is always on. I read somewhere that it could be the Y-SUS board as there are large IC's that can fail but there are no large IC's on my Y-SUS board. There is a small Control board in the middle that has some large IC's. The power-supply and Z-SUS have been very hot as the circuit boards have very dark heat spots. The power-supply voltages check out fine. I've found 5.1, 17, 60, and 201 volts. The remote control functions seems to work just fine. Hoping someone has seen this on the "PK" series. I would appreciate any advice as I'm trying to prevent it from going to the landfill.
    Thanks in advance!
  • sordids999
    • May 2013
    • 2156
    • uk
    Re: LG 50PK950-UA Flashing Screen.
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • dbuergi
      Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
      by dbuergi
      i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
      Any ideas where to look?...
      11-07-2024, 10:57 AM
