UN65F6300 LED's failing
  • pyr0ball
    • Sep 2013
    • 10
    I'm having an almost identical issue to the one posted here
    My symptoms:
    Dim lower part of the screen. Top part will flicker at regular intervals when brightness is higher.
    I've already purchased a replacement SMPS module after poking around on the power supply and concluding (incorrectly) that the square wave on voltage I was seeing was from the supply.
    I'm very handy with a soldering iron but didn't want to disassemble the TV entirely unless I could find some replacement LED's to swap first. Searching the forum hasn't really turned anything up and I can only really google the full LED strip modules which either come in single sets or overpriced kits (looking at $150+ minimum for the wrong size modules I would need to swap led's from).
    Is there a way I can isolate which specific LED's are faulting?
    I've got access to an oscilloscope, DMM, and lots of other equipment if someone would be able to give me a rough guide on what to look for.
    Panel module: CY-HF650CSAV1
    suspected LED strip modules: 2013SVS65F L11 & 2013SVS65F R9
  • CapLeaker
    Leaking Member
    • 8120
    Re: UN65F6300 LED's failing
    You do that 2 ways. With your DMM in diode mode, or a CV CC regulated PSU. LEDs work on CC (constant current). You can measure the voltage on each string and we can tell on what string that bad LED is.
    HIgh resolution, straight shot pictures of your screen fault and the boards would be nice too.
    • pyr0ball
      • Sep 2013
      • 10
      Pics:
      Top of the power board
      Bottom of the board
      LED connector top w/ pinout silkscreen
      LED connector bottom with silkscreen (and my testing wires)
      Power output silkscreen
      Test image 1
      Test image 2
      Test image 3
      • pyr0ball
        • Sep 2013
        • 10
        Had a chance to review those pics?
        • CapLeaker
          Leaking Member
          • 8120
          what happens if you set the backlights low as they can go? Does the flicker stop?
          What are the voltages on the led connector? Measure from 1- to 1+, all 4 strings
          • pyr0ball
            • Sep 2013
            • 10
            Flicker does stop on lower brightness.
            I'll have to test again to measure across the poles. I was testing from + to ground before.
            • freakaftr8
              • Oct 2012
              • 3743
              That is for sure a bad LED or 2 in the strips. These power supplies load on 3 or 4 strips at a time. Noticed your nearby. I repaired at 75 inch version. Not a walk in the park I might add.
              • Pipolups
                Corsair K70 LUX RGB dying LEDs
                by Pipolups
                Hi there !
                I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                10-08-2024, 11:58 AM
              • THE GTC
                Insignia NS-37D20SNA14 intermittent LEDs
                by THE GTC
                So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                11-03-2020, 02:40 AM
              • ongobongo
                Ram Modules with undderfill - tricks for desoldering
                by ongobongo
                I'm working on another Lenovo E14 gen 2 AMD here which has a ton of errors with the factory soldered DDR4 ram chips. I do have a donor board here from which I'd like to use the modules and swap them. Unfortunately, the modules are glued down with underfill, which i have never worked with before.
                I tried with a lot of heat on the donor board but the modules won't come loose.
                Are there any hint or tricks when it comes to dealing with underfilled chips/ic that could help here
                Ongo
                06-02-2024, 02:18 AM
              • gabrielA7
                Zotac GTX 1080 8GB / No video / Error reported on all memory modules!
                by gabrielA7
                Hi guys!!
                I have this video card on my bench, it turns on and the screen goes black!
                I used MATS but it showed an error in all memory modules, when writing!
                I once got a 1060 with the same symptom, all modules were defective, I rebaled the GPU and it stayed the same.
                Remember that I have all the debts ok, 1.35 Vram and such!
                Could the problem really be in the GPU?
                Could it be the BIOS?
                Thank you in advance!​
                06-05-2025, 09:04 AM
              • VitalComputing
                Replacing Mode Indicator LEDs
                by VitalComputing
                I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                I thought I could just put a resistor...
                09-17-2023, 04:43 PM
