Samsung UN65F6350AFXZA
  • moandkaren
    • Apr 2016
    • 16
    Bottom half of tv is dim and flickers. Self diagnostics had TCom board as ng, replaced it but no luck. Seems to be a backlight issue. Is this the power supply or main board or backlight circuit. Any help appreciated.
    Mo
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung UN65F6350AFXZA
    If you look through the back panel can you see the backlight flickering ?
    • moandkaren
      • Apr 2016
      • 16
      yes the bottom half backlight is for sure flickering
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok you need to take the lcd panel apart to the backlight then and get us some images.
        • moandkaren
          • Apr 2016
          • 16
          Changed out power board no luck. I am not sure how to get at backlight. Do I have to remove screen.
          Thank you so much for trying to help.
          • Louis82
            • Feb 2012
            • 240
            Yes. You need to disassemble the screen until you get to the LED strips. Be careful when you open the screen because is very fragile. If you break it, the game is over. There is no way how to fix a broken screen.
            • moandkaren
              • Apr 2016
              • 16
              I think I have a problem with backlight LED strip. What a pain
                Does it flicker less or not at all if you turn down the backlights level on the on screen user menu to may be 50%?
                • moandkaren
                  • Apr 2016
                  • 16
                  No
                    The LEDs are too far gone then.
                    • moandkaren
                      • Apr 2016
                      • 16
                      To clarify, when I turned down the brightness, the bottom half of the tv was just totally dark, almost not visible, but I did not notice if the lights were still blinking. If the LED are the problem, why do they flash and why would it be the whole bottom.
                        Are you talking about the Brightness or the Backlights level, they are not the same?
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          You said the Leds were flashing so it has to be them if thats the case ?
                          • moandkaren
                            • Apr 2016
                            • 16
                            Great question, on the samsung I usually select the brightest mode. Which one I turned down, heck, I wish I remembered. Have it completely apart right now so a little hard to check. You are thinking its the led's since they are flashing, so must be backlights?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              So looking through the back cover you can actually see the Leds flickering ?
                              • moandkaren
                                • Apr 2016
                                • 16
                                Right now have it completely apart. Reconnected power board and Main board and the bottom half definitely flicker. I thought to test to see if its actually the led's was going to try the bottoms on top and the tops on the bottom. Any other suggestions since I do not have any testing equipment.
                                  Can we see the pictures of how the LEDs are setup?
                                  • moandkaren
                                    • Apr 2016
                                    • 16
                                    A little more detail top 3 rows light, middle 3 rows are dead, bottom 5 flash.
                                    Middle ones need replacement? attached photos show connections and configuration
                                    • moandkaren
                                      • Apr 2016
                                      • 16
                                      on closer inspection, the bottom 5, one row only has half blinking
                                      • moandkaren
                                        • Apr 2016
                                        • 16
                                        Well I think I got it. Two left and one right are out. I am having a dickens of a time finding replacement. Need two 2013SVS65F L11 and one 2013SVS65F R9. Any suggestions appreciated.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
