SAMSUNG LN40B750U1FXZA, is not turning ON, only steady red light
  • luendel
    • Oct 2014
    • 18
    Hi, my son TV is a SAMSUNG LN40B750U1FXZA (PICTURE 1), is not turning ON.
    He said the night before was working perfect, he just turn off and the next day is not working anymore.
    I start reading some threads; learning terminology and some tips to find the problem and this is what I find...
    The only signal of life is the steady red light in front (PICTURE 3), this means some board still working. I touch the power up sensor next to the red light, nothing happened but if I tray turning on with the remote control the red light GOES OFF and nothing happened. NO PICTURE, NO SOUND.
    Now, NO LIGHTS on back T-Con board (PICTURES 5, 6, 7), it is supposed to see a red light on the DIGITAL AUDIO OUT port and amber or green in the ETHERNET port.
    I just open the back cover (PICTURE 2) and inspect the cap's on the power board (PICTURE 4), they looks good.
    I disconnect the ribbon cable from the power board (PICTURES 8, 8a, 9, 9a, 10) and connected the power cable and BACLIGHT IS ON in the TV.
    I take volt measurements on the pins (PICTURE 11) in the terminal connector according the table and I got good 5.1 Volts on 5.1 pins, 5.1 on SB but on 13V pins the measurement was 12.6V almost 13V.
    I check the removable Fuses (2) on the power board, they are good. I don't see any other fuse on the other boards.
    I was thinking the T-Con board is the problem but I'm confuse because the red light in front is connected to this board. Why if no lights on this board still red light in front ON?
    I inspect the main board (Center Picture 2) for burns but looks good.
    Which board is the problem?
    Thanks for your help Forum.
    Re: SAMSUNG LN40B750U1FXZA, is not turning ON, only steady red light
    We need the DCV readings of all the pin (except the GND pins) on that white connector on the power supply/inverter combo board, Samsung BN44-00284A Power Supply / Backlight Inverter: http://www.shopjimmy.com/samsung-bn4...wer-supply.htm, when Power switch is activated.
    You MUST provide the pin number, follow by names, and follow by the DCV reading so we can see what Voltages and signals are present or not present and go from there. Notes: you have to have all the connector back in places when making the measurement.
    Black probe of the meter to the chassis.
    BTW. 12.6V on the 13V pin is fine.
    • luendel
      • Oct 2014
      • 18
      Ok thanks I'm going to do that!!
      • CapLeaker
        Leaking Member
        • 8136
        I am guessing the isn't any PSON / BLon coming back from the main board.
        • luendel
          • Oct 2014
          • 18
          1) Readings WITHOUT white connector:
          PIN EQUAL READINGS
          1-------PS--------- 0.794 VDC
          2-------SYNC------- 6.8 mVDC
          3-------SB----------5.2 VDC
          4-------GND-----------------
          5-------GND-----------------
          6-------GND-----------------
          7-------13 V-------12.38 VDC
          8-------13 V-------12.38 VDC
          9-------GND-----------------
          10-------GND-----------------
          11-------GND-----------------
          12-------GND-----------------
          13-------5.1 V-------5.2 VDC
          14-------5.1 V-------5.2 VDC
          15-------5.1 V-------5.2 VDC
          16-------5.1 V-------5.2 VDC
          17-------GND-----------------
          18-------GND-----------------
          19-------13 V-------12.38 VDC
          20-------GND-----------------
          21-------13 V-------12.38 VDC
          22-------13 V-------12.38 VDC
          23-------INV-ON-------3.298 VDC
          24-------I-PWM-------7.9 mVDC
          25-------E-PWM-------4.84 VDC
          26-------GND-----------------
          27-------5V DET-------5.2 VDC
          28-------GND-----------------
          29-------GND-----------------
          30-------GND-----------------
          2) Readings WITH white connector but NO press power in remote control, just connect power cord and red steady light:
          PIN EQUAL READINGS
          1 PS-------20.2 mVDC
          2 SYNC-------21.2 mVDC
          3 SB-------5.2 VDC
          4 GND-----------------
          5 GND-----------------
          6 GND-----------------
          7 13 V-------0.6 mVDC
          8 13 V-------0.7 mVDC
          9 GND-----------------
          10 GND-----------------
          11 GND-----------------
          12 GND-----------------
          13 5.1 V-------0 VDC
          14 5.1 V-------0 VDC
          15 5.1 V-------0 VDC
          16 5.1 V-------0 VDC
          17 GND-----------------
          18 GND-----------------
          19 13 V-------0.6 VDC
          20 GND-----------------
          21 13 V-------0.7 mVDC
          22 13 V-------0.7 mVDC
          23 INV-ON-------0 VDC
          24 I-PWM-------10.3 mVDC
          25 E-PWM-------0 VDC
          26 GND-----------------
          27 5V DET-------0 VDC
          28 GND-----------------
          29 GND-----------------
          30 GND-----------------
          3) Readings WITH white connector AND press power in remote control, NO red light in front:
          I can't read constant value number on the voltmeter.
          PIN EQUAL READINGS
          1 PS-------goes High to low....High to low....High to low
          2 SYNC-------goes High to low....High to low....High to low
          3 SB-------goes High to low....High to low....High to low
          7 13 V-------goes High to low....High to low....High to low
          8 13 V-------goes High to low....High to low....High to low
          13 5.1 V-------goes High to low....High to low....High to low
          14 5.1 V-------goes High to low....High to low....High to low
          15 5.1 V-------goes High to low....High to low....High to low
          16 5.1 V-------goes High to low....High to low....High to low
          19 13 V-------goes High to low....High to low....High to low
          20 GND -----------------
          21 13 V-------goes High to low....High to low....High to low
          22 13 V-------goes High to low....High to low....High to low
          23 INV-ON-------goes High to low....High to low....High to low
          24 I-PWM-------goes High to low....High to low....High to low
          25 E-PWM-------goes High to low....High to low....High to low
          27 5V DET-------goes High to low....High to low....High to low
            The Standby Voltage (SB) is fluctuating when connected to the main board so it can be dues to bad caps in the SB power supply or the main board is loading the SB supply too much so it goes into shutdown/restart cycle.
            BTW, this power supply board has pull-up resistors for doing the board self test mode which you did when you disconnect cable between the Power supply and the main board then the backlights come on.
            Also the PS-ON signal for this board is >0.7VDC = ON, <.1v = OFF.
            It can still be weak SB power supply since in self test mode the loads are very light, but when main board is connected then it will see heavier loads. You can use dummy load to draw about 1A as a start on the SB supply to see if it can handle that or not.
            • luendel
              • Oct 2014
              • 18
              Hi Budm,
              How I can perform the dummy test?
                You can use two 10 Ohms 5W resistors connected in parallel to make 5 Ohms 10W resistor, that will draw about 1A of current from SB power supply, just connect the resistors between SB pin and GND pin.
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • ohren
                  by ohren
                  09-08-2023, 05:24 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                  09-07-2024, 05:50 AM
                • FMstatic
                  Sony KDL-48W657D (main board protect, green light steady at the same time red light s
                  by FMstatic
                  Diagnose (panel problem)
                  - main board replaced- still no good
                  - panel board check all supply present and correct voltage
                  - hang flex ribbon main board to panel (error 5blink) but when connected again nonstop red blink no pose and green light steady
                  -SDA and SCL supply 3.3v panel board
                  -BL is good simulated
                  Guys help me any suggestion
                  Main board protect 12v shut off when connected to panel board
                  06-08-2021, 09:29 PM
