Mode#47LG70 screen blanking LG LCD 47"
  • cheapshot
    • Jul 2012
    • 41
    • Bahamas
    Good day all. The referenced TV will cut on fine but as soon as a video source is plugged to ANY HDMI port, the screen's backlight will cut out and then back on and will do this about 10 times then stop for a few seconds then start again. This is not a flashing or strobe effect like I have seen a lot on here addressed. Its like the backlight literally cuts out then back in every half second.
    With no video input the TV stays on fine. Where should I start with this one?
    Re: Mode#47LG70 screen blanking LG LCD 47"
    Does it do that using other Video ports?
    • cheapshot
      • Jul 2012
      • 41
      • Bahamas
      Have not tried others but I can if needed? Wouldn't this point to power supply board if the inverters are powered from this board?
        Power supply is unstable, or inverter board is unstable, or the BL-ON or DIMMING signal form the main board are not steady.
        You have to take Voltage measurement at the least.
        • cheapshot
          • Jul 2012
          • 41
          • Bahamas
          ok where should I test first? I can post back with what I see a bit later
            Why don't you try other Video ports first?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4456
              • Italy - Milan
              Hi, do you have made tests always with the same video source? Same hdmi cable? Tried with source inserted with the tv sw.on from cold?
              • cheapshot
                • Jul 2012
                • 41
                • Bahamas
                ok will try other sources but from cold screen will blink if source is inserted
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • spice_disc
                  Vizio TV M50-C1 reboot cycle and static on screen
                  by spice_disc
                  I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                  The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                  09-08-2024, 02:37 PM
