32lg3000 sound ok but no picture
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Greetz
    Got this tv today with sound but the picture comes after 15-20 minutes
    In this 15-20 minutes there are wertical stripes in different colours.
    https://www.dropbox.com/s/kprpxqdl3f...14734.jpg?dl=0
    The caps look OK
    Where to start looking
    thx
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: 32lg3000 sound ok but no picture
    Lift one cable from the tcon to the panel and see if one half of the screen is clear then replace that one and repeat with the second.
    • CapLeaker
      Leaking Member
      • 8189
      clean and reseat the LVDS ribbon cable with 99% alcohol, make sure the connectors they go in are clean. Same thing with the ribbon cables going from the TCon to the main board. Also try heating the Tcon first with the hair dryer and see if there is a difference.
      Post a high resolution straight shot picture of your Tcon board.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Originally posted by capleaker
        clean and reseat the lvds ribbon cable with 99% alcohol, make sure the connectors they go in are clean. Same thing with the ribbon cables going from the tcon to the main board. Also try heating the tcon first with the hair dryer and see if there is a difference.
        Post a high resolution straight shot picture of your tcon board.
        +1
        • nbdy
          • Aug 2015
          • 162
          • Croatia
          OK,cleaned the ribbon cables (3 pcs,2 up,and the down to motherboard)
          Heated the t-con for cca 5min. and the picture came after 5 min ...
          Have another 37" lg - could the t-con fit in this tv
          the t-con is from sharp (forgot to take the picture,but all elements seem to be ok)
          https://www.dropbox.com/s/9svvn0nhhz...-l500.jpg?dl=0
          this is the board (pic from net)
          Must say when the tv works for cca 30min-1hour,when i turn it on after 10 minutes it displays the picture immediately
          • CapLeaker
            Leaking Member
            • 8189
            I can't see much on that picture... it is too blurry. See if there is a tantalum capacitors or something similar on it. Just solder some low esr lytic cap in parallel, if you have no means of checking. Like lytics, tantalums are polarized too.
            Run the LCD panel with only one ribbon cable connected at a time, like dick barton suggested. See what this produces.
            I have no idea if the tcon fits the other TV without any board numbers.
            • nbdy
              • Aug 2015
              • 162
              • Croatia
              The faulty TV is 32LG3000 , the other one is 37ld465 (it has a broken screen)
              I could take all boards from the other tv (going to search if it fits)
              here are better pictures (3 pcs) of the sharp board
              https://www.dropbox.com/s/kslu69qid8...73703.jpg?dl=0
              https://www.dropbox.com/s/vlwhm7nm5i...73710.jpg?dl=0
              https://www.dropbox.com/s/yryy35g37m...73717.jpg?dl=0
              @Capleaker : could you be more precize where to solder the cap,and what value
              even if left or right side connected,all the same
              rechecked the boards,they are not the same ...
              • nbdy
                • Aug 2015
                • 162
                • Croatia
                Found the capacitors ( i think the orange ones on both sides) but the marking I2264,41NM4 i can't find anything
                • nbdy
                  • Aug 2015
                  • 162
                  • Croatia
                  Lifted left - right side with stripes
                  Lifted right - left and right side without picture
                  • CapLeaker
                    Leaking Member
                    • 8189
                    No, the other tcon wont fit that TV. However the tcon for this one is cheap to be had for like 10 bux.
                    One side of the tcon working while not the other side, I'd be replacing that tcon first.
                    • nbdy
                      • Aug 2015
                      • 162
                      • Croatia
                      More like 35 bux. Little expensive,but i will have to order it ...
                      Try first to reflow the board ...
                      • nbdy
                        • Aug 2015
                        • 162
                        • Croatia
                        Ok,the new board (tcon) arived,and the problem is the same ...
                        Help again,should I look at the main board ???
                        • CapLeaker
                          Leaking Member
                          • 8189
                          only way to proof it that the main board is bad is with a steady picture and hook up an oscilloscope to the LVDS.
                          • nbdy
                            • Aug 2015
                            • 162
                            • Croatia
                            Don't have any oscilloscope ...
                            But now a smoke cam from the motherboard and :
                            https://www.dropbox.com/s/4xu76qq3s5...93040.jpg?dl=0
                            found out that
                            mbw3216-501tf burned is,and
                            4925b mosphet out of service is ...
                            the mosphet can i find,but that filter bead 500ohm is a question for me
                            • CapLeaker
                              Leaking Member
                              • 8189
                              Sorry, that pic is too blurry. A marking FB woud be a ferrite bead.
                              • nbdy
                                • Aug 2015
                                • 162
                                • Croatia
                                https://www.dropbox.com/s/phksjon2q2...8_HDR.jpg?dl=0
                                this is a better pic
                                its Q1104 and L416
                                • nbdy
                                  • Aug 2015
                                  • 162
                                  • Croatia
                                  Could it be that the new tcon board coused the motherboard to burn ???
                                  • CapLeaker
                                    Leaking Member
                                    • 8189
                                    I am not a 100% sure, but it seems that those pins could be for the panel power. The inductor is just used a filter. What is written on Q1104?
                                    Honestly, I don't really know what happened. You could have shorted something unintentional that blew this circuit, or something is bad on either the tcon or the panel causing excessive current draw.
                                    Where to go from here? You need to either fix the main board and hope nothing else is toasted besides the blown IC and the inductor, maybe another Tcon and you may be back at square one before. Unless you have some sort of testing equipment (o'scope), know how to solder SMD and you just want to try to repair it for educational purposes, I'd say part it out and look out for a different TV that's easier to fix.
                                    Up to you how far you want to go and how much $$$ you are willing to spend on this TV.
                                    • nbdy
                                      • Aug 2015
                                      • 162
                                      • Croatia
                                      Well this TV costs me 35$ till now,over 100$ I would not go ...
                                      Soldering is no problem have all the equipment,but no osciloscope (it was in this month plan) ...
                                      the q1104 is 4925b mosphet,but I didn't find any value for that mbw3216-501tf (L416)
                                      thx
                                      • nbdy
                                        • Aug 2015
                                        • 162
                                        • Croatia
                                        Any one knows what the
                                        MBW3216-501TF 500 ohm is and where to buy it
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
