Pioneer Pro-1150HD Trap switch
  • jeffer76
    • Sep 2011
    • 76
    • US
    I am working on a pro-1150hd that would turn on and display some writing on the screen that it was turning on. Tv would then shut off after a minute or 2 with 12 blue blinks.
    I took the back off the tv and now have a trap switch failure. I am unable to turn the trap error off.
    Tried display, <^<>power. Nothing happens. Using Pioneer remote CU-SD110.
    Please Help
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Pioneer Pro-1150HD Trap switch
    Don't know if this will help
    From internet:
    To get the TV out of "trap" mode, this is what needs to be done with the remote: Press and hold the "display" button for 1 second and then wait 7 seconds. Next press theses buttons in the following order: Left arrow, up arrow, left arrow, right arrow, and then the main power button on the remote. That's what fixed it.
    https://www.youtube.com/watch?v=dFZV0TADHBU
    • jeffer76
      • Sep 2011
      • 76
      • US
      I have tried this process many times. I was told by someone on ebay that repairs these Main boards for the 12 blue blink errror that you cant exit the trap switch error without first fixing the Main board. He also said that his repair doesnt always fix my symptom.
      Problem: TV would turn on and display message on screen "Please Wait....". After a minute to two minutes, tv would shut off and blue light blink 12x.
      Does anyone have experience repairing these Main Boards? Common parts or loose connections? Hate to send a board in for repair with no guarantee.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Images of the boards please and of the please wait image ?
          AFAIK the 9G pioneer sets did not have trap switches on any models, so are you sure you have a trap switch fault and not another code?
          • R_J
            • Jun 2012
            • 9628
            This model refers back to this manual PDP-5080HD
            I found this instruction that has a wait between pressing the display and the other buttons
            1. Press the display button then release the display button.
            2. Wait between 3 and 7 seconds
            3. Press and release the <, ^, <, >, and power buttons in sequence.
            Panel will now turn on in service mode.
            4. Press muting button 3, 4 or 5 times depending on model you are working on.
            Until the display shows the initialize page.
            5. Press and hold the display button until the error indicator (red LED) on
            either the panel or the media receiver goes out.
            6. Exit service mode by pressing the power button on the remote.
            • mmartell
              • Oct 2013
              • 3189
              I have a post on here where I detailed how to do this reliable by counting as you're doing it. At least it worked for me reliably. Will try to find it.
              There is a regulator that fails somewhat commonly but I don't know if it's used in your set and it's not on the main board it's on the tanshi (?) board. I believe this is the component being replaced by those offering the repair service on ebay. As to the name of the regulator I definitely don't have that on hand but can find out if you'd like.
              • mmartell
                • Oct 2013
                • 3189
                Just remembered norcal75 has a youtube video where he replaces this part in a Pioneer plasma tv. Check it out it may help.
                • jeffer76
                  • Sep 2011
                  • 76
                  • US
                  Thanks for the responses. Tried multiple count sequences for trying to enter the service mode. Noticed multiple posts about counting one one- Thousand, two one-thousand and so on. None of which worked for me.
                  I am interested in knowing about the regulator that goes bad. If anyone has a link to a YouTube video that would be appreciated.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Here it is.
                    https://youtu.be/eZNAv0m5f7M
                    • tmhobadcap
                      Pioneer VSX-522-K remote control not working???
                      by tmhobadcap
                      I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                      At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                      12-24-2020, 01:44 AM
                      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 05:30 AM
                    • Natob82
                      Micro Momentary Push Switch?
                      by Natob82
                      Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                      12-21-2022, 05:22 AM
                    • grimacelord
                      NEC TurboExpress On/Off Power Switch Replacement Help
                      by grimacelord
                      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                      11-09-2023, 09:49 AM
                    • SluggerB
                      Help making a switch work the opposite way with a relay
                      by SluggerB
                      I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                      I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                      It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                      02-07-2025, 07:57 PM
