LG 32LV2500 power light blinks twice, goes dim, set won't power on
  • kturnerga
    • Apr 2010
    • 20
    I have an LG 32LV2500 TV that won't turn on. When powered and the button is touched I get two slowly flashing red lights and a dim white light. I get no picture or sound. I replaced the power board (original board had no bad capacitors) just in case it were the issue. The replacement came from Ebay off what was said to be a busted screen tv. I got the same result.
    Does the blink pattern sound familiar? Would it be a time waster to recap the board just on the off-chance (I read that LG's have bad caps).
    Re: LG 32LV2500 power light blinks twice, goes dim, set won't power on
    You need to provide pictures of the whole backside of the TV showing all the board first.
    What DCV measurement did you make on the power supply board to find out if it is good or bad?
    What's the level of your experience in electronics repair?
    • kturnerga
      • Apr 2010
      • 20
      Here are the pics of the back end and the motherboard and power board on the 32LV2500. I haven't tested the 5v or so coming to the logic board as of yet. I disconnected the cable you saw to eliminate the board above (driver board?) being the issue.
      My experience is basic when it comes to electronics. I work as a computer repair tech and have recapped many a motherboard in my day. However I have no ESR meter capability. The fuses on the power board ohm out good, however. The FAQ on fixing TV's as seen in the reply was helpful.
      Could it be that the smashed-screen special I got for a power board was bad as well? I hope that's the scenario I'm facing. When the power board was replaced it repeated the two reds and the white when the power was pressed on the tv. So I bought a mainboard only to find that it was incompatible (connector to the button array was too small) despite the number (on the 75ohm box) being the same. Main boards specified for the 2500 are scarcer than hen's teeth.
      KT
        The picture of the power supply board is to out of focus for me to read the P/N on the bar code sticker.
        We need to be able to see the label for the pins of the white connector of the power supply board that goes to the main board, and also for the connector that goes to the LED driver board.
        • kturnerga
          • Apr 2010
          • 20
          Here we go...and it really does say BAD on the bar code. Hmmmm....
          • kturnerga
            • Apr 2010
            • 20
            Here are even more pictures because I had trouble with the barcode picture
              LG EAY62169402 (EAX62865601/7) Power Supply for 32LV2500-UA
              http://www.shopjimmy.com/lg-eay62169...upply-unit.htm
              Pictures provided by shojimmy.
              We need the DCV readings of all the pin except the GND pins, black probe to the chassis.
              Top row you can get from the top side of the board, the bottom row you will need skinny probe to get through the back side of the connector.
              You MUST make sure to put pin name of each pin and follow by the DCV reading when the power switch is activated.
              Example:
              Power ON = ????V
              24V = ????V
              • kturnerga
                • Apr 2010
                • 20
                Sorry it took so long. The values of top are
                per right to left on diagram topside
                3.4
                24
                0
                0
                3.5
                3.5
                0
                0
                11.9
                11.9
                11.9
                0
                The bottom pins were hard to gauge because of my needle taped to the electrode on + but from LEFT to right per the diagram topside of the connector:
                .5
                0
                0
                0
                0
                0
                3.5
                3.5
                0
                0
                0
                0
                Where my 24v went on two of the bottom pins I do not know.
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • lapfix
                  HP OMEN NO power no light
                  by lapfix
                  HP OMEN : DAG35DMBAD0
                  NO power ,no short ,no corrusion
                  Consumption : when charger plg in = 0.004 amp
                  Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                  when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                  No light at power button led
                  All coils resistances :
                  Pl 2001 =3v measured with kohm.
                  pl 2004 = 5v measured with kohm
                  pl 6001 = 49.7ohm
                  pl 4012 = vccsa = 24.4 ohm
                  pl 3001 =...
                  11-03-2025, 07:48 AM
                • Alicat
                  Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                  by Alicat
                  Stopped by this site trying to fix my parents Panasonic Plasma TV.
                  Model number is TH-50PZ85U
                  Power comes on and the red power light stays on solid.
                  Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                  I also hear a few clicks.
                  I also think my parents said there was a thunderstorm and the TV failed after that.
                  Section 6 in the service manual talks about power and no screen,...
                  10-30-2024, 10:09 AM
                • ipatch
                  troubleshooting microsoft surface pro 4 no power no led charge light
                  by ipatch
                  hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                  10-05-2023, 11:59 AM
                • russpall
                  LG 39ln540v - red light flashes twice, no power to LED driver?
                  by russpall
                  Hi there,
                  I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                  The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                  08-27-2024, 01:07 PM
