Vizio VX32 Shut Down
  • Chicd
    • Jun 2015
    • 40
    Vizio VX32 HDTV10a powers on/backlight/no picture...powers off in 30 seconds. Can power right back on w/switch but shuts down again.
    Disconnected inverter board...same shut down
    Standby and 12v all OK
    Changed out power and main board...same problem...
    What am I missing?
    Re: Vizio VX32 Shut Down
    So you have backlights it means the power supply, inverter, lamps are OK.
    Did you check the T-CON board?
    Pictures of the whole backside of the TV so we can see what we are dealing with?
    • Chicd
      • Jun 2015
      • 40
      Will get photos...disconnected tcon harness...still shuts off after about 30 sec. Failed after a lightning storm/voltage spike
        Need to check the T-CON board, when you disconnect the T-CON then the main board may sense that the T-CON is not active since there is no power for the T-CON to send OK signal back to the main board.
        The new board can also be bad, you will never know what you will get from seller these day.
        • Chicd
          • Jun 2015
          • 40
          Did not replace tcon board...looks like it is hard to get to...
          • Chicd
            • Jun 2015
            • 40
            Would bad tcon cause shut down? Doesn't seem like an overheating problem since I can power it on right away...
            Thanks for your help....wanted to learn about tv repair for many years...really fun but I lack the depth of knowledge to really do serious trouble shoot. I have replaced caps, vr's etc with success....
              Yep, not easy to get to the T-CON on this model.
              https://www.badcaps.net/forum/attach...9&d=1472950967
              See that bare wire with two black Ferrite beads to the left of the LVDS T-CON connector and next to the Lytics cap?
              See if you have 12Vdc on that exposed wire.
              The 30 seconds may also be due to no Video signal detected so it goes into standby mode.
              • Chicd
                • Jun 2015
                • 40
                Forgot to mention that I have no led lighting on the front panel where it blinks for codes....does this model have a standby light other than the vizio logo?
                I will check the voltage this AM...
                • Chicd
                  • Jun 2015
                  • 40
                  Only 5.1v on that bridge wire. Some other tests...
                  U7 3.3/1.3/0
                  U33 5.1/3.3/2.1
                  U9 3.3/1.5/0
                  U8 5.1/3.3/2.1
                  U4 5.1/3.3/2.1
                  U2 5.1/3.1/2.1
                  This is on the board that was the replacement...original board was about the same...U7 and U9 had 0v on third leg...
                    U2 is wrong, it should have 3.3V output, you are getting 3.1V.
                    P/N of U7, U9?
                      BTW, you indicated that you do have 12VDC, you mean the 12VDC is present at both end of the SMD fuse for the 12V supply on the main board, right?
                      • Chicd
                        • Jun 2015
                        • 40
                        Is that a fuse with the ferrite beads...?
                        I just tested the bare wire/exposed on top...
                        Thought it was just a bridge wire....
                          There are two white fuses with gold ends right by the main board connector that goes to the power supply board, one fuse should have 5V, another one should have the switched 12V.
                          • Chicd
                            • Jun 2015
                            • 40
                            ...was testing voltage on U10 #1084/0717DL and accidently shorted pin to the center one(clipped) and had an audio squeel...pulled power...turned back on and backlight stayed on until I powered it down....powered back on and shut down after 30-40 sec.
                            U7 is ANC1117/F0734F U9 is K1117S15/736
                            Still only have 5.1v on wire with ferrite beads...
                            Will retest the 12v fuse...
                              I am confused, so you have the 30 seconds shutdown on the original board, and also on the replacement board, but now you indicated that you had shorted out the pin on the regulator and you are now getting 30 seconds shutdown, so the shutdown happen before or after you shorted out the regulator on both board?
                              • Chicd
                                • Jun 2015
                                • 40
                                When pin was shorted out and I powered off....powered back on and back light remained on until I powered off after testing. Powered back on and it shut down after 30 - 40 seconds...
                                Both boards give 30 sec shut down...
                                • Chicd
                                  • Jun 2015
                                  • 40
                                  11.9 v on both sides of fuse...
                                  I must have a bad voltage regulator...maybe a fluke by having same problem with replacement board....was a used board...
                                  • TechGeek
                                    Computer Geek
                                    • Jan 2015
                                    • 2254
                                    5V fuse tested? Exposed wire tested?
                                    Permanently Retired Systems:
                                    Kooky and Kool Systems
                                    sigpic
                                      Right now you know that U2 has the wrong output Voltage and the PS-ON to the main board is present otherwise you will not have that switched 12VDC on the fuse on the main board.
                                      5VSTBY fuse and Voltage is OK otherwise you will not have DCV on the regulator or the PS-ON signal.
                                      • Chicd
                                        • Jun 2015
                                        • 40
                                        I have repaired several Vizio, samsung, emerson, crosley and a few other brands...this one is pushing my limited knowledge of circuitry....thanks for your continued help.....I have a continuing supply of TV's and am having a good time.. Next one to tackle is a 70" vizio and a 55" Pioneer
                                        Want to fix this little bastard first......
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
