samsung ln52a750r1fxza red light blinks
  • LITEZONER
    GO BOLTS!
    • Mar 2010
    • 223
    i read all the threads on these sets, I have 5V standby at PS, no other voltages are present, all it does is red led in front blinks very slowly, PS caps LOOK good no bulging or leaking, but i am wondering if all those little caps on the back of the main board could be the culprit? seems the main turns on the ps on these units Thanks
    39 Soldering Iron burns And Counting
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: samsung ln52a750r1fxza red light blinks
    The little caps on the Main Bd don't usually go bad...not saying they don't, though....but do you know how to Self-test the power Bd?
    • LITEZONER
      GO BOLTS!
      • Mar 2010
      • 223
      I sure don't know about a self testing procedure or anything like that, is there some sort of flow chart? thanks for the reply.
      • LITEZONER
        GO BOLTS!
        • Mar 2010
        • 223
        Okay so just poking around here, Pushing down on cn801 the connector that plugs into the power board BN-44-00201A, I get a relay click and the source light flashing
        • LITEZONER
          GO BOLTS!
          • Mar 2010
          • 223
          Plugged the LVDS cable back in, forgot it was unplugged...... and source light does not flash anymore, just the standby light flashes a couple of times then goes out, Looks like i need to re work some solder joints on the PS board? for further testing
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Could we see clear pics of the Pwr Bd, please...especially the connector that goes to the Main Bd. i.e. to determine which pins are Stby 5V and etc?
            • CapLeaker
              Leaking Member
              • 8158
              Post a high res, straight shot picture of the back of the main board.
              • LITEZONER
                GO BOLTS!
                • Mar 2010
                • 223
                so i get the 5.1V on pin 3 no other voltage is present, i have not tried holding down the spot that makes the relay click and measure the voltages, included is a picture of the back of the main board as well. Thank you
                • CapLeaker
                  Leaking Member
                  • 8158
                  try to turn the TV on and measure the DC V on all the pins on the PSU connectors CN801 and CN803.
                  Post the pin out name with the voltage measured.
                  You may want to check the tantalum caps on the back of the main board as well.
                  • LITEZONER
                    GO BOLTS!
                    • Mar 2010
                    • 223
                    Okay so here is what i found so far, based on the relay clicking in i was led to think of a cracked solder joint or loose one, re worked a few suspicious welds, found big blob of solder crossing the pins in the picture, got out my wick and cleaned it up, Put board back in, blew fuse. URG! so back to the bench under magnification, i noticed a jumper that I think is suppose to be there but it was missing, so i checked over all the welds on the cold side and soldered in a Jumper in that position in the picture, Put board back in Blew Fuse. URG! Again.
                    • CapLeaker
                      Leaking Member
                      • 8158
                      if the fuse blows instantly, you got something shorted on the primary.
                      I see you circled something on the first picture, but I cant read it. I don't think there should be a jumper there. What is the P/N on the IC? Check all the devices installed on the long heat sink.
                      • steves7839
                        • Nov 2014
                        • 200
                        If the TV ever worked, a missing jumper is missing by design (i.e. an option) and should be left as is. With power disconnected, take Ohms readings between all voltage pins and ground. This should uncover the location causing the fuse to blow.
                        • LITEZONER
                          GO BOLTS!
                          • Mar 2010
                          • 223
                          IC part is on the Hot side and number is 2A20112 the only thing i can think of is i shorted it when removing the big blob of solder from it that was shorting across three of it's pins, but it wasn't blowing the main fuse before . SIGH.....
                          • LITEZONER
                            GO BOLTS!
                            • Mar 2010
                            • 223
                            this is the location on the IC where there was a big blob of solder i removed most of it and that's when the fuse started blowing, the two pins circled are still shorted together, I was given this set to repair two others in hopes of getting this one repaired to use for a while, it appears it has been worked on at least once and it pretty toasty, meaning that when i slightly move a component you can hear the solder cracking, maybe time for a fresh board???
                            • LITEZONER
                              GO BOLTS!
                              • Mar 2010
                              • 223
                              thinking of removing ic and testing for fuse blowing? steve i removed the jumper i soldered in, i used the shop J picture as a reference thinking there was suppose to be a jumper there, as i said i have no idea who has been in here before, But i messed up somewhere when trying to reflow some joints, basic stuff, now i have the short, made a small problem worse. URG!!
                              • LITEZONER
                                GO BOLTS!
                                • Mar 2010
                                • 223
                                thank you for all you help, I know when i am in over my head and now that i have a serious short i am near drowning, I'm opting for a replacement board, sucks, but thats how it goes, sometimes you win and sometimes you loose. thanks again to everybody.
                                • CapLeaker
                                  Leaking Member
                                  • 8158
                                  My guess is that you shot that PFC IC, maybe the gate drive circuit and some Mosfets. Pin 16 of that IC was VCC for the PFC IC. Pin 15 is the Master Mosfet drive terminal. So yep... shouldn't have soldered that bridge to those 2 pins.
                                  • LITEZONER
                                    GO BOLTS!
                                    • Mar 2010
                                    • 223
                                    do you guys know if the power supply's are interchangeable on these is has the BN44-00201A I am looking at the BN44-00202A they look nearly the same? Thanks
                                      Shojimmy does not list any sub for the 201A.
                                        09-07-2024, 05:50 AM
                                      • Samunggg
                                        Samsung UN70NU6900FXZA - Red Light Blinks 2 Times Then Screen Flickers
                                        by Samunggg
                                        I've happened upon this TV, it came with no power cord or remote and it seems to be experiencing a common issue where the red indicator light blinks 2 times then the screen flickers as if it's trying to turn on. No picture, no sound. I suspect the functions of the TV are in good order and that the underlying issue is with the power button which is missing. It's just a white tab where the button should be which means I can't cycle it.
                                        I wanted to know if there is anything I can do or if I should just get a replacement module with the hopes it will fix the system. Alternatively if...
                                        09-06-2023, 06:39 PM
                                      • Elecfronicsssss
                                        DA0NJJMBAG0 charging light blinks
                                        by Elecfronicsssss
                                        Laptop motherboard DA0NJJMBAG0
                                        PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                        CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                        GUIDE ME WITH THE PROBLEM..
                                        SUMMARY-
                                        1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                        2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                        05-12-2025, 02:32 AM
                                      • Jackching
                                        Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                        by Jackching
                                        I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                        04-15-2024, 05:14 PM
                                      • Yanleb
                                        Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                                        by Yanleb
                                        Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                                        If they are not compatible why did Samsung give them the same part number to begin with?
                                        08-04-2025, 11:35 PM
