Vizio fading Light asking for help and Thank you
  • LITEZONER
    GO BOLTS!
    • Mar 2010
    • 223
    ViZio E420i A0 5v good at power supply, TV shows standby light when i first plug it in, then it fades slowly to dark, push power, same light comes on then fades, unplugged LED strips and continue to have a power light indicator at first, but again fading to dark. replaced main board still same symptoms, Pulled panel cables one at a time still same standby light fade issue, disconnected IR board and still same issue, checked LED strips from pink wire to white with basic OHM meter, shows open between these wires no shorts, Replaced power supply, still same fading standby light issue. Thank you very much for your help folks, you are all very much appreciated, Glad this place is here.
    39 Soldering Iron burns And Counting
  • Diah
    • Feb 2013
    • 6376
    Re: Vizio fading Light asking for help and Thank you
    did you checked the V DC on the main big cabs of power supply if the voltage stay high or fading?
    • LITEZONER
      GO BOLTS!
      • Mar 2010
      • 223
      one cap 450V 100uF voltage across cap is steady at 152V
      • LITEZONER
        GO BOLTS!
        • Mar 2010
        • 223
        VOUT1 and VOUT2 voltages stay about the same with or without LED strips plugged in 142-157 and 88-92 respectively. I guess the strips are in OPEN condition not shorted? also the unit should still power up with the LED Strips disconnected?
        • LITEZONER
          GO BOLTS!
          • Mar 2010
          • 223
          when i push power the VOUT Voltages start to drop way out of range, they will go all the way down to 4V, then when I push power again, they return to normal range with LED's plugged in
          • LITEZONER
            GO BOLTS!
            • Mar 2010
            • 223
            same condition with LED's strips unplugged, vout drops way out of range when i push power, but returns when i push power again, seems to me this is a bad Power supply or the secondary's anyway? what do you think?
            • Diah
              • Feb 2013
              • 6376
              post photo on yours PWB and listed the voltage you have at stand by state and after you press power on
              • LITEZONER
                GO BOLTS!
                • Mar 2010
                • 223
                put old PSU in and same condition, seems the LED driver is on the PSU?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Take a look at:
                  https://www.youtube.com/watch?v=W2PFEdrL4lU
                  • LITEZONER
                    GO BOLTS!
                    • Mar 2010
                    • 223
                    okay plugged in video source, have power on, no back lights, have vout1 holding steady at around 140 and Vout 2 holding steady at around 90 both fluctuate by a few volts, Have audio no video, but image is viewable through flashlight method.
                    • LITEZONER
                      GO BOLTS!
                      • Mar 2010
                      • 223
                      Thanks for the video, watch that one some time back, I am fairly certain at this point it's time to look at the led strips, they are getting proper voltage but no light.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        "Weak' LEDs on the backlight strip/s. I don't know why this happens....but I came across a few TVs with these same symptoms. Turned out to be some LEDs lighting.
                        • LITEZONER
                          GO BOLTS!
                          • Mar 2010
                          • 223
                          found some bad strips, cannot seem to find replacements in stock anywhere, any suggestions? Thank you Panel is LC420DUG JFR1
                          • sleeper123
                            • Aug 2016
                            • 17
                            Do you want to replace the strips as a whole or just the bad LEDs on the strips?
                            TVs fixed:
                            Vizio E470i-A0
                            LG 50PT350
                            Vizio E470i-A0
                            LG 47LN5400
                            LG 47LN5750
                            Vizio E470i-A0
                            Vizio VP322
                            Magnavox 40ME325V/F7
                            Emerson LF501EM5F
                            • LITEZONER
                              GO BOLTS!
                              • Mar 2010
                              • 223
                              not real familiar with SMD soldering and do not have the right equipment, so probably all the strips, thought about finding somewhere to send it out for replacement of the bad one's because i cannot locate the strips.
                              • ozzy214
                                • Nov 2013
                                • 319
                                • usa
                                Got pics of the strips? I may have them or comparable? Depends more on the panel than the tv....and I do think I have a known good set here. I wont charge much for them.
                                • LITEZONER
                                  GO BOLTS!
                                  • Mar 2010
                                  • 223
                                  here is a pic, thanks Oz
                                  • ozzy214
                                    • Nov 2013
                                    • 319
                                    • usa
                                    Closes thing I have is this, looks very similar. Except polarition lenses are different. There is a whole set of them from one tv, but some strips have 6 leds instead of 5.
                                    Maybe you can make them work?
                                    I'm here and there.....quickest method is 5705071838 to reach me.
                                    I can take pictures of the entire set of strips if you want.
                                    • x_orange90_x
                                      Vizio E550i-A0 no power, no standby light
                                      by x_orange90_x
                                      I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                      11-20-2023, 09:49 AM
                                    • p-top
                                      Vizio, E60u-D3, no standby light, no ps_on
                                      by p-top
                                      Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                      main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                      PS voltages
                                      1 VSNS -2mV
                                      2-5 LED-OUT -2mV
                                      6-10 GND -2mV
                                      11 +16VS 16.29V
                                      12 AC-DET 3.929V
                                      13PS-ON -3mV
                                      14 +16VS 16.29V
                                      15 +16VS 16.29V...
                                      11-27-2023, 10:44 AM
                                      Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                      by sam_sam_sam
                                      I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                      I also have back when Light of America had these light bulbs available for yard lights
                                      The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                      While the Lithonia lighting fixture has all most certain bulb failure
                                      So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                      I have only had this light fixture for not more than a year if it...
                                      07-02-2023, 03:45 PM
                                      LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 03:40 AM
                                      LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 09:10 PM
