Vizio SV420XVT1A missing 12v on main board
  • bikerbuddy
    • Jun 2011
    • 134
    Re: Vizio SV420XVT1A missing 12v on main board
    Sorry If you are confused Budm ,the only time I can see the 12 and 24 volts is when I jump the ps/on to 5v . when I remove the jumper I do not see the 12v nor the 24 v ,
    • bikerbuddy
      • Jun 2011
      • 134
      U16 and U45 no power
        OK, so the main board is still not sending the PS-ON even though we are getting the correct DCV on the new regulator.
        Looks like we need even more in-depth troubleshooting of the main board at this point.
        • bikerbuddy
          • Jun 2011
          • 134
          Ok Budm what would you suggest i try next , remember on post 19 I mention that the main chip with the heat sink is getting hot .
            Without the circuit diagram for the main board, then there is not much you can really do at this point since all we are able to test are the regulator ICs, and they are OK at this point. I think you will have to get new main board.
            • bikerbuddy
              • Jun 2011
              • 134
              Yes Budm after I felt the heat on the main chip I figure I will have to go that way also , any way thanks and I will post how I conclude this post later
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • ygorsan
                by ygorsan
                🧩 Problem Summary:
                • I
                07-28-2025, 08:34 AM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
              • JDC
                (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                by JDC
                ONN 100012588
                Issue: No Power, Then Rebooting After Main Board Change
                Short answer: replace main board and power board
                Technical answer: replace main board and Q306 & Q307 on power board.
                Long answer:
                TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                07-15-2022, 07:39 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
