Vizio M420NV no backlight
  • jman100
    • Aug 2016
    • 5
    Hi guys,
    Looking for some advice on a Vizio M420NV. The screen comes on and the tv functions fine, audio and video, but the backlight is completely out. I was only able to tell the picture was still there by holding up a flashlight to it.
    There is never any flicker at all from the LEDs, they completely do not come on. I'm a novice on hardware stuff so any advice on what to test is appreciated. I looked for a BL_ON pin but I cannot find one labeled that, and don't know what it would look like.
    Thanks in advance!
    Re: Vizio M420NV no backlight
    We need good clear pictures of the whole backside of the TV showing all the boards, and then pictures of each board.
    • jman100
      • Aug 2016
      • 5
      Sorry for the delay, here are a bunch of pics.
      • CapLeaker
        Leaking Member
        • 8352
        turn the tv on and check the DC V on the BLon pin.
        • jman100
          • Aug 2016
          • 5
          Once again sorry for the delay.
          BL_ON shows .03 volts while the tv is off, and goes to .12 when the tv is turned on.
          • CapLeaker
            Leaking Member
            • 8352
            That sux. Main board isn't sending BLon signal...
            since the tv comes on and the backlights stay off, it's a bad EEPROM on the main board.
            Your choices are to get a new replacement main board, or buy the repair kit at Shopjimmy for your board number 0171-2272-3174. You would have to change 2 two ICs (U14 and U33) on the main board. U14 fixes the frozen on welcome screen, U33 is for the backlights.
            • jman100
              • Aug 2016
              • 5
              Darn. Oh well, I did acquire the TV for free. I might get the repair kit.
              I assume there's no way to bypass or manually try to turn the backlight on to make sure?
              • CapLeaker
                Leaking Member
                • 8352
                To force the PSU on, only leave the backlights connected. Take two 1k ohm resistors and jump STBY voltage to PSon and STBY voltage to BLon. Plug it in and the backlights should be up. If not, try to put a third resistor between STBY and ADJ.
                • sricechex
                  • Mar 2018
                  • 17
                  I know this was a while back, but I thought this may be a source for diagnosing an almost identical problem.
                  I have a m420nv with no backlight, good image, white logo.
                  VLED voltages of 164v.
                  BL_ON from 0.4v off to 0.8v on.
                  Does this sound like an eeprom failure on the main board?
                  Is there further diagnostic information necessary or suggested?
                  Thanks!
                    • 12323
                    • U.S.
                    Unplug tv, then unplug powersupply board from mainboard, plug tv back in turn tv on see if backlights come on, that will work if it has pull up resistors if not you have to do like CapLeaker instructs in post # 8.
                    • sricechex
                      • Mar 2018
                      • 17
                      Great! Thank you, nomoresonys. I'll give that a shot.
                      If I can confirm that the backlights can be forced on successfully, can I be relatively confident that there is an eeprom failure on the mainboard? (is there a source for ideal voltages at those signal pins?)
                        • 12323
                        • U.S.
                        As CapLeaker says in post 6, if you don't have ps_on coming from the mainboard, most likely a mainboard fault, you could try heating the mainboard a little with a hair dryer, see if it trys to come on or anything changes.
                        • sricechex
                          • Mar 2018
                          • 17
                          I think he was taking about BL_ON , Not PS_ON?
                          That certainly makes sense, I'm just inexperienced as to what voltage constitutes "getting no signal. "
                          I'm getting 0.8v, but should it be a known board signal voltage like 3.2 or 5v?
                            • 12323
                            • U.S.
                            http://www.shopjimmy.com/vizio-3642-...for-m420nv.htm The board is 134 bucks there but they have eprom kits for around 20.
                              • 12323
                              • U.S.
                              https://www.ebay.com/itm/Vizio-3642-...ty!43616!US!-1
                              One there for 80 bucks, looks like these boards are pretty costly.
                                • 12323
                                • U.S.
                                My bad I meant to say BL-ON.Yes I would expect about 3 or so. budm usually says 2.5 or greater equals backlights on and if I recall 1. or lower equals backlights off, something like that.
                                  • 12323
                                  • U.S.
                                  Yes usually around 3, you are way low there.
                                  • sricechex
                                    • Mar 2018
                                    • 17
                                    If the backlights do work when forced, I'll give the eeprom-swap a try. I'll report relevant information as I find it.
                                    Is the standby voltage what should be expected in a live signal?
                                      • 12323
                                      • U.S.
                                      Did you try test in post #10.
                                        • 12323
                                        • U.S.
                                        https://www.youtube.com/watch?v=mUvclBfaMXg Testing powersupply by itself, unplug all other boards, he's using the ground pin for testing because he has board out of tv, you can just use the metal back of tv or other suitable ground for testing, IF you can't get a steady standby reading while testing with this methed, it's a powersupply board problem. Could try that to verify powersupply. CAREFUL HIGH VOLTAGE FROM THE HOT SIDE CAN BE DEADLY.
                                        • howardc64
                                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                          by howardc64
                                          Problem
                                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                          Model & Board Pics
                                          Conflicting Spec
                                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                          https://www.shopjimmy.com/vizio-gj-2k1...
                                          10-10-2024, 01:16 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                        • Jidis
                                          Need T-Con Advice (Vizio P602ui-B3)
                                          by Jidis
                                          I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                          He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                          09-22-2025, 05:10 PM
