Philips 42PFL7603D/10 - Freeview intermittently not detecting channels
  • Mat R
    • Aug 2016
    • 3
    Was hoping someone might be able to point me in the right direction of diagnosing and DIY repair on my Philips 42PFL7603D/10.
    We've had it since 2009, and use the onboard Freeview receiver, as well as an Apple TV and a recently added Zgemma satellite receiver. However most of the viewing is done via the Freeview receiver.
    The issue is that lately when I power the TV on, either from standby or from a powered-off state, the Freeview receiver doesn't detect the stored channels. I need to power cycle the TV several times before it does. The screen is black... the channel menu displays the stored channel name but that is it. It is also difficult to change the input at this stage, it seems to get stuck in the channel list.
    Starting it up on any of the other inputs (HDMI1, HDMI2), the TV works fine for those sources.
    Any info would be greatly appreciated.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Philips 42PFL7603D/10 - Freeview intermittently not detecting channels
    Try a firmware update to see if it will cure the problem.
    http://www.p4c.philips.com/cgi-bin/c...=42PFL7603D/10
    • Mat R
      • Aug 2016
      • 3
      Hi - thanks for that. I actually updated the f/w some time ago, it is on the latest version.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        If there's a problem with the IC retaining the data then updating could restore.
        • Sharpa
          Repair attempt Philips 55OLED804/12
          by Sharpa
          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
          The symptoms when bought: Philips logo appears then tv turns off
          Things tried so far:
          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
          11-22-2025, 08:30 AM
        • alro7779
          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
          by alro7779
          Hello, guys!
          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
          09-14-2025, 12:25 AM
        • G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
          by G33RT
          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
          It does power up when pressing the power button.
          I already try the power button while plugin the plug with no result.
          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
          Could this be an PSU or eMMC issue ?
          07-19-2025, 03:43 AM
        • double_DD
          Philips curling iron - is this a common AC cable?
          by double_DD
          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
          08-18-2025, 10:04 AM
        • janos6662000
          Philips 47PFS7509/12 LCD TV problem
          by janos6662000
          Hi
          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
          When i applied cable signal to check image, i had normal picture, but TV was restarting.
          I downloaded original firmware and applied the update, but the problem remained.
          From a colleague i received a "factory package software" which is a lot bigger.
          I made another firmware update, but still did not solve the problem.
          Somewhere on the way the error got worse, because at the moment the...
          08-12-2025, 12:54 PM
