Vizio E701i-a3 Backlight issue
  • michaelart
    • Dec 2012
    • 14
    Thanks for looking. I have a Vizio E701i-a3 tv that when turned on the backlight comes on for a second or so and then turns off. I do get an image when shining a flashlight on the screen (the message says RGB signal not detected, TV will power off). Another note, the backlight goes out while the Vizio logo is present after TV power on. I have replaced the power supply board with the same result.
    This TV has three pairs of wires that power the LEDs. Since I do not have a wiring diagram, the only thing I could do is to remove each pair, one at a time. I still got the same result, no backlight.
    Is there any possibility that the mainboard may be the culprit?
    Any other ideas?
    Thanks again,
    Michael.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Vizio E701i-a3 Backlight issue
    It could be a Backlight issue as the LED Driver will shut down with an open LED or if you disconnect a string of LEDs.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      x2 on a bad LED.
      • michaelart
        • Dec 2012
        • 14
        I was afraid that might be the case.......just hoping that it could be something else.....makes me a bit nervous taking a panel apart. Like a bull in a china shop.....lol. Thanks guys, appreciate the input.
        • michaelart
          • Dec 2012
          • 14
          I purchased replacement led strips (all 3) and they tested good when I hooked them up. I am a bit nervous about disassembling such a large panel assembly. Has anyone done this or have access to the instructions on how to properly disassemble and replace. This is one time that I would prefer some instructions than figuring out being that it is such a large panel. Thanks again for your input.
          • budwich
            • Jul 2015
            • 3097
            not to take you back a bit too far.... but did you try disconnecting the tcon cables (one side or the other) and see what happens?
            • michaelart
              • Dec 2012
              • 14
              I plugged in the replacement LEDs in the place of the original ones and they light up and stay lit unlike the original which would seem to prove that one of the LED strips in the TV is faulty. Just not looking forward to disassembling the panel.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8352
                good luck and let us know how you progressed.
                • bruce@2305
                  • Sep 2016
                  • india
                  I have the same issue in Samsung HD led TV . I'm fresh to led tvs .led turn off and on automatically when I increased the backlight. But reduced backlight screen working fine please help me
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    Please can you make a new thread as this is a totally diffrent tv in your new thread please post clear pictures of the diffrent boards used in your tv and one showing them all connected together and please let us know the full model number of the tv thanks.
                    • Yanleb
                      Vizio M70-D3 4K with dark spots backlight issue
                      by Yanleb
                      I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                      On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                      I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                      03-22-2022, 01:06 AM
                    • Mectronik
                      Vizio m601d-a3 backlight issue
                      by Mectronik
                      Hello, I'm working on a Vizio m601d-a3 with a backlight issue that I am having a difficulty diagnosing it. As it sits, the tv powers on, displays the Vizio symbol and with nothing hooked up it will then display no signal but you can only see half of the screen. I know it's a back light issue because the picture is there without light behind it, as I can see it by doing a light test. I've taken off the paneling and done a visual inspection. If I disconnect the tcon ribbon cable to the affected side then the entire half of the screen goes away. I've checked voltages at the LED driver from the main...
                      11-05-2023, 10:20 PM
                    • Acnologia
                      Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
                      by Acnologia
                      Hello to all members of badcaps.
                      Another brainstorming that i have been messing with for months as a side project.
                      Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
                      I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
                      Step 1.
                      Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
                      Machine > Doesn't give display it's really dim.
                      Step 2.
                      Use the same...
                      11-05-2025, 04:02 AM
                    • Cornito
                      TCL 65C715 backlight issue
                      by Cornito
                      Hello team,
                      I'm back with another topic.
                      It's a 65C715 TCL tv with backlight issue.
                      But the problem is a bit strange.
                      When I took this tv from the marketplace backlight didn't work but picture was ok.
                      Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                      Putting all back together the tv worked fine for weeks. => Contact issue??
                      Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                      06-09-2024, 02:24 AM
                    • SS454
                      vizio e650i-a2 backlight flashes then turns off
                      by SS454
                      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                      panel: au optronics T650HVN05.4
                      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                      https://www.shopjimmy.com/vizio-56-0...-power-supply/
                      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                      08-20-2020, 03:57 PM
