Digihome (Vestel) LED Backlighting Problem
  • Diah
    • Feb 2013
    • 6437
    Re: Digihome (Vestel) LED Backlighting Problem
    i think yours DMM 3 Volts one.. so its not really correct as i said there no such 1050 however you are correct now to know which need to change... what are the serial label print on the strips..?
    • CapLeaker
      Leaking Member
      • 8327
      disregard.
      • bigalxyz
        • Aug 2016
        • 39
        disregard.
        I thought in diode mode it was measuring resistance, ie 1050 ohms. Is that not the case?
        In resistor test mode I get the same numbers ie 1050 ohms in one direction, and open circuit (infinite ohms) in the other direction.
        • bigalxyz
          • Aug 2016
          • 39
          I'm not sure what the serial number is on the LED strips - I'll check tomorrow. I've already ordered some replacement LEDs though which I should be able to "stack" onto the existing strips (discussed this earlier in this thread). eBay so they should be with me in a day or two, fingers crossed.
          Thanks for your comments tonight, very grateful.
          • CapLeaker
            Leaking Member
            • 8327
            The voltage drop is measured in Diode mode.
            • bigalxyz
              • Aug 2016
              • 39
              Not sure what I'm looking at in that case. 1050 volt drop?! Or could it be showing millivolts? Why would I see the exact same voltage drop number as I see in ohms using the resistor test function. This is all very confusing.
              Anyway - I think we've successfully identified the suspect LEDs so I suppose the first job is to replace those and then see what happens.
              • CapLeaker
                Leaking Member
                • 8327
                I think your meter is rubbish. You should not have the same readings in Ohm or Diode mode. Anyhow, I am sure it's the LED's.
                • bigalxyz
                  • Aug 2016
                  • 39
                  The meter is quite old so perhaps it has a fault. Maybe it's time to replace it.
                  • CapLeaker
                    Leaking Member
                    • 8327
                    Good idea. Some decent low cost meters, look maybe at Uni-T. High Quality is more expensive, look at Fluke or Agilent / Keysight.
                    I am pretty sure you'd be confused, if you get rubbish readings.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #70
                      This is just total mess, they wont break down like that anyway. I will come back when you finish faffing.
                      • CapLeaker
                        Leaking Member
                        • 8327
                        I had to look up "faffing". Never had heard of that word, but I like it.
                        The polite translation for:
                        "to aimlessly waste time doing useless tasks".
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #72
                          Lol just uneeded mess IMO, I will let them get on with it
                          • Unimatrix
                            (Vestel) Telefunken XF43G511 - Thermal problem
                            by Unimatrix
                            I came across this forum because I need some advice about my Telefunken XF43G511 TV. It is originally a Vestel device. For some time now I have had the problem that the TV gets a black screen when the electronics are heated up. The backlight is still there and the sound still works. It's just the screen itself that goes off. When I switch off the TV and it cools down, the TV works again after a while. Could you please give me some advice on what could be causing this problem? I have also attached some photos of the electronics.
                            Kind regards
                            Thomas...
                            11-19-2023, 08:39 AM
                          • theone111
                            by theone111
                            3. Problem: TV shuts down
                            07-22-2024, 10:36 AM
                          • Zeonalbasta
                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                            by Zeonalbasta
                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                            09-13-2024, 01:17 PM
                          • Gibon378
                            Problem with stopping audio and video for no reason
                            by Gibon378
                            PC Specs:
                            • CPU: Ryzen 5 1600
                            • GPU: GTX 1080 Palit JetStream
                            • MOBO: ASRock ab350 PRO4
                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                            • PSU: XFX 650W (don't remember what model)
                            • OS SSD: ADATA SP920
                            • OS: Windows 10 21H2
                            Problem description:
                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                            11-19-2022, 09:41 AM
                          • perzyk23
                            Lenovo T580 - LCD Panel problem - error 0288
                            by perzyk23
                            Good morning,
                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                            10-25-2024, 12:42 AM
