Panasonic TC-P50G20 HDMI Failure
  • chronofar
    • Aug 2016
    • 7
    I had lightning strike the house and it turns out an XBOX that was plugged into the TV via HDMI was not on a surge protector, and since this time no HDMI ports receive input. The TV still appears to function fine (turn on and display a picture and navigate menus), but there just isn't a signal.
    As such it seems perhaps the strike may have shorted out my A board (TXN/A1MGUUS), however I wanted to see if there are other steps I should perform to verify prior ordering the part off of ebay. I don't have ready access to a voltage meter or resistors, or much experience testing with such things. I do have experience building and troubleshooting computers, so from what I could see replacing the A board should be within my sphere of knowhow (take a bunch of screws out, remove the connectors, replace board, reverse).
    Any advice is appreciated.
  • chronofar
    • Aug 2016
    • 7
    Re: Panasonic TC-P50G20 HDMI Failure
    Here are some pics of the back. There's nothing visually wrong that I can tell. Looking at the schematics it looks like everything with the HDMI should be contained on the A board, unless there was a general power failure, which I can find no evidence for (again with the aforementioned lack of direct voltage testing). If anything jumps out at anyone else, or if indeed the A board seems like a good bet, please let me know. Thanks!
    • chronofar
      • Aug 2016
      • 7
      Have I done something wrong, or skipped some forum etiquette here? Please let me know if additional information is needed to provide any advice. Thanks!
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        No you havent , everything is ok! Including the pictures.
        To high current went through your x-box into the mainboard from your tv. You are lucky the tv turns on and displays a picture.
        The current has fried the HDMI controller on the mainboard. You can repair it yourself if you know how to desolder the chip on the mainboard and resolder the new chip back on.
        If you don't want to repair it yourself then order a mainboard on ebay/shopjimmy and simply replace it.
        You can also use component. Its the same quality as HDMI but without sound.
        TNPH0834 is your mainboard.
        Normally there is also a white sticker that says the version of your board. Its probably hidden under the metal shield on the right hand side.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Ps , even if you do replace the hdmi controller chip. There can be more parts damaged on the board. I would replace the mainboard and replace the chip whenever you feel like it so you can keep it as a spare.
          • cliff_hootarski
            • Jul 2006
            • 411
            TNPH0834AE. Looks like a suffix AE.
            • chronofar
              • Aug 2016
              • 7
              Great thanks guys!
              • chronofar
                • Aug 2016
                • 7
                So after replacing the A board now I'm getting 10 blinks and the unit won't power on. Does this indicate something bad with the replacement? Or something else wrong?
                • cliff_hootarski
                  • Jul 2006
                  • 411
                  Me thinks you received a bad board, assuming it is correctly hooked back up and no other connectors are loose. I know it's a pain, but you could put your old board back in to make sure.
                  • chronofar
                    • Aug 2016
                    • 7
                    Put the old board back in and it's back to how it was before, powers on but no HDMI. So I guess this board is going back. Just to make sure there's no procedures I should have to do to tell the TV to use the new board right? Should be as simple as disconnecting the old, plugging in the new and powering on right?
                    Got this one in eBay (high rep seller). Any reputable supplier for this type of thing or am I just going to need to try another chop shop?
                    Thanks!
                    • cliff_hootarski
                      • Jul 2006
                      • 411
                      Keep buying until you get one that works! Did the same a few years back on the G15 model, got lucky on the 2nd one purchased.
                      • SluggerB
                        Panasonic TH-50PX80 killed by lightning strike, help me save her!
                        by SluggerB
                        Yes it's a 17 year old Panasonic plasma!
                        I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                        06-04-2025, 07:02 PM
                      • BadTelly
                        HDMI ports not working - Panasonic model number TX-P50XT50B 50"
                        by BadTelly
                        Suddenly all HDMI ports stopped working on a Panasonic 50" TV. This is model number TX-P50XT50B and has worked fine for years.
                        The TV turns on but no joy on either HDMI-1 or HDMI-2 and I've tested it using an input device and cable that works fine on another TV via HDMI.
                        Thank you in advance for any help/ advice.
                        Kind regards,
                        Bad Telly
                        11-26-2022, 11:26 AM
                      • aliougm
                        Marantz SR4003 AVR HDMI board issue, seeking for help
                        by aliougm
                        I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                        Connection as below:
                        Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                        If I bypassed AVR then HDTV screen color be good.
                        I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                        3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                        I replaced all...
                        04-30-2022, 12:21 PM
                      • JDC
                        (SOLVED) - Panasonic TH-50PZ80U - No HDMI
                        by JDC
                        Issue: Panasonic TH-50PZ80U works fine but has no HDMI output.
                        Easy solution: replace main board.
                        Advanced solution: replace HDMI chip on main board.
                        Unless you've got the time, tools and the hands of a surgeon, skip the advanced solution. For you beginners out there reading this, you would need to use a combination of a heat gun, flux, solder, and probably a microscope to succeed. If there is someplace you can send the board in for repair, you can go for that. From what I've read elsewhere, I don't think this TV will even do 720p.
                        If none...
                        08-10-2022, 06:10 AM
                      • japlytic
                        Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                        by japlytic
                        With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                        An examination of the HDMI CEC wiring...
                        07-10-2022, 09:48 PM
