Vizio e3d320vx need help please
  • Greywolf74
    • Jul 2015
    • 5
    I have a Vizio e3d320vx 32 inch LCD TV. When I press the power button the power light comes on, the screen initially lights up and displays the vizio logo for a couple seconds and then it goes black. It then momentarily lights up (but still no picture) and then goes dark again. If I shine a flash light along the edge of the screen I can see that there is a picture and I do have sound. Im assuming the PSU/inverter needs replaced but Im not sure if it could possibly be something else instead.
    Thoughts?
  • tiki66
    • Jul 2016
    • 39
    • Croatia
    Re: Vizio e3d320vx need help please
    Could be PSU or inverter, or maybe even CCFL lamps
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Images of the boards used in the set please ?
      • Greywolf74
        • Jul 2015
        • 5
        Here ya go.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          What is the part number of U300
          Photo's courtesy Shopjimmy
          • Greywolf74
            • Jul 2015
            • 5
            I have no idea what U300 is
            • CapLeaker
              Leaking Member
              • 8223
              post #5, first picture, bottom right. There is a connector, measure all pins the DC voltages and post them back with the corresponding pin out name.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                U300
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • howardc64
                  Vizio SmartCast TV software bug that looks like hardware
                  by howardc64
                  Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                  It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                  11-16-2024, 05:17 PM
