I am not sure if this right place to put this thread but since it is video.I thought it might be,I am looking for schematic or service manual.What happened is a had a bad power surge and it took out my dvr8-4000.I am trying to find schematic so I can try to repair it.Any help would be appreciated thanks.
Dvr8-4000
Re: Dvr8-4000
May be you can show us the pictures of the board inside, especially the power supply board which more likely to be made by an OEM so even if you find the service manual for the unit, it probably will not have the power supply diagram.Never stop learning
Channel: BIOS Requests ONLY!
Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
by corrizeHello, I search this connector (oxydated).
It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
Do you know how to find this connector please ? What is the exact name for find it ?
by sam_sam_samThis Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...-
by ktmmotocrossEVGA 360AIO with LCD. Aio and lcd not work. Cannot find NUC1261NE4AE Nuvoton that have burn mark on it.
Anyone knows where to find it?08-02-2025, 06:40 AM - Loading...
