Philips 39pfl2608/f7 no power
    Re: Philips 39pfl2608/f7 no power
    Originally posted by 1beertap
    budm,
    The backlights are on a long as I have power plugged in. Using three 1k resistors jumped from 3.3v to BL_SW, BL_ADJ and P-ON-H2. The connector is unplugged from main board. Unlike the other member's thread, PROTECT3 does have 3.1v on it.
    I see in the comments you say if the PROTECT 3 signal is OK, then we will need to look at PROTECT 1 signal. What voltage can I expect to see on it?
    So the cut PROTECT3 jumper is solder back together?
    PROTECTION1 is activated if the AMP+13V or P-ON+21V is not present, so check the Voltages on those jumpers.
    • 1beertap
      • Mar 2009
      • 219
      Yes, you are correct, I did solder PROTECT3 back together. I tested the following points with the 1k resistors still in place and the backlight is on:
      AMP+13V = 12.5V
      P-ON+21V = 21.1V
        So at this point you have problem with the main board.
        • 1beertap
          • Mar 2009
          • 219
          After putting the TV away for a bit, I went back to it and found the problem to be the ribbon cable between the power supply and main board. There were three broken connections on it. I guess I could be slapping myself but that would hurt!
          Thanks budm for the help. Cheers!
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            I could help with the slapping... if you want?!
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
