Sharp LC-46LE830E Blinking light.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    Got this tv that won't turn on. It's a led tv with leds on top side and bottom side.
    When the mains is plugged in the V logo starts to blink immediately. Looks like a 1 blink that repeats forever.
    I only measure 5v going to the mainboard. All other voltages on the connector from PS to mainboard are 0V.
    Already replaced the mainboard , tv turned on for 2 / 3 seconds and is now also doing the same....
    Any suggestions?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sharp LC-46LE830E Blinking light.
    Backlights is one blink from what I remember, checked the Led drive and return voltage ?
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Yes i was thinking the same. Where is the LED driver? The leds are connected directly to the PS
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Lol the driver is built into the Psu buddy, the pins on that are labeled, does it state what the voltage should be per string ?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Sorry , new to these led tv's. Got a attic full with plasma's and 1 led tv
          No they don't list the voltages. There is absolutely no voltages on that area except 5v on diode D7918 and a optocoupler.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Hmm seems like Psu fault too me, so nothing else apart from 5v on the motherboard connectors too ? Also what are the Pson and Blon signals doing when you try to power the set up ?
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              I got +/- 13V on the primary side of the optocouplers/diode's but only 5v on the secondary side. Looks like mainboard problem to me? New one does not work either so im confused.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Nothing , the led on front that looks like a V starts blinking immediately.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Ok , i found a shorted resistor on the power supply. Its R718. So looks like a bad power supply.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    So after repairing some plasma tvs i decided to take another look at this LED tv.
                    I got another mainboard and now the tv somehow turns on. The white V led stays on.
                    One of the 4 led strips did not turn on as on the picture so i replaced that strip. Now all 4 strips light up as on the picture. The led strip on the picture comes out of a working led tv so im sure its ok.
                    The led on the mainboard next to the cpu is flashing.
                    The voltages on the connector going to the led strips are 88v , 143v , 88v , 143v , 57v , 143v and 88v. One or more leds are dead?
                    Any ideas?
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      On all sides the led strip turns on very faint. Some leds are completely off and the other ones are on. But very dimmed light.
                      On the new strip all leds are on but also dimmed. I think some leds are pulling the voltage down?
                      • mmartell
                        • Oct 2013
                        • 3189
                        How do you have seven measurements if there are only four strings ? Try measuring the value for each +/- pair.
                        Are you sure the resistor you replaced was shorted and not just a low-ohm value ?
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          Aah ofcourse! As i said , im new to these led tv's.
                          I just measured every wire lol. It would mean that 1 strip is not returning voltages or not correct voltages.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Yes the leds should be uniform in brightness, might be indicative of failing leds.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              Replaced all 4 strips , still same symptom. when i remove the small white cable going from T-con to the mainboard when the tv is on , the backlight comes on and then it goes into protection. ( Because it cant find the t-con ).
                              The LCD panel is disconnected from the tv at the moment. Tv must work without the panel right ?
                              It looks like a bad t-con....?
                              • YasaCh
                                Sony kdl 40p5500 red light keeps blinking 3 times
                                by YasaCh
                                Hello...
                                my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                i opened the back cover no sign of damage on the powery suply or motherboard
                                when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                07-07-2025, 11:53 AM
                              • Michael Long
                                No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                by Michael Long
                                I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                Dead / No Power / No Standby Light results after power company had three
                                consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                09-13-2022, 06:55 AM
                              • Cookybaby
                                Samsung UN60ES6500FXZA Power Supply Issue
                                by Cookybaby
                                Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                Make: Samsung
                                Model: UN60ES6500FXZA
                                Power Supply P/N: BN44-00525A
                                Symptoms: The TV was...
                                08-20-2023, 12:26 PM
                              • icareservicezone
                                Synology DS918+ blue light blink
                                by icareservicezone
                                Synology DS918+
                                Model name : GDI41L2
                                p/N: 08-06GDI4116
                                Version: V1.6
                                Problem : blue light blink...
                                05-24-2025, 11:53 PM
                              • matty24
                                Samsung UE50MU6172 - red light blinking
                                by matty24
                                Hello. I have problem with Samsung UE50MU6172.
                                TV won't turn on, red standby light is blinking.
                                Power supply BN44-00807A is fine. I replaced it with the new one.​
                                Main board BN41-02568B (BN94-12530E)
                                I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                03-02-2025, 08:57 AM
