PN50A550 friends, was clicking, no start fixed that but no picture
  • jjona5
    • May 2016
    • 8
    So I got the set to fire up like it is supposed to but all I get is a black screen with red static on a mostly black screen. Anyone witness this before? It had a few cold solders on the power supply and a main board problem.
    AKA PN50a550s1f, PN50A55os1fxza
  • jjona5
    • May 2016
    • 8
    Re: PN50A550 friends, was clicking, no start fixed that but no picture
    I just decided to hook up my cell phone to the audio inputs and then hook an n64 up to the video and kept hitting input on the remote. Turns out the audio is working so I guess I might have a bad tcon board eh?
    • R_J
      • Jun 2012
      • 9588
      Not likely, Plasma tv's don't have a t-con, could be ysus or zsus boards, do a search for your model, looks like lots of threads
      • jjona5
        • May 2016
        • 8
        Well I guess its a logic board not a tcon. How do you test a ysus or zsus?
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • nbnb
          Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
          by nbnb
          I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
          Any idea what is causing the clicking sound? Any easy way to...
          11-23-2019, 12:03 PM
        • S14Sr20det
          Nec E557Q lines and fade to black picture FIXED
          by S14Sr20det
          Trash picked this tv from a local business, had a garbage image and would fade to black within second then cut off. It would get shorter and shorter every time.
          Narrowed it down to the right side of the panel by unplugging half the t con
          One side had a great picture the other was black and distorted still.
          Down to the buffer boards… found yet another set of two esd diode arrays. One leg had a 60 ohm short to ground and would get lower the more attempts made to turn the tv on.
          Soldering iron and some chip quick knocked both of them off and...
          06-17-2023, 02:55 PM
