Sharp LC-60SQ15U TV DPS-167CP - No power
Re: Sharp LC-60SQ15U TV DPS-167CP - No power
What can you say about the removal of the supervisor, maybe maybe that's the reason?PC7904 is used to turn on Q7902 to supply vcc_on so it can be left out of circuit for now.
If you also remove pc7903 and D7908, pin 4 of ic7903 should be about 7volts, If it does not come up, try isolating just pin4 from the circuit trace, this will eliminate any other component on that line as well.Comment
Seller say these NEW, and say on 5 pin should be 15V for start IC and there will be no voltage on the 4th contact until it starts IC , R7918 not open (0Ω)
Does it make sense to desolder the supervisor? Or can I just remove the resistors on pins 1 and 3? I read on other forums that it happens to be a common problem his of not give starting ICLast edited by romasik; 05-21-2022, 05:41 PM.Comment
What do you have in place for D7950? Maybe disconnect whatever is in there and see if the vcc comes up.
The ic's startup cell IS providing the initial 9volts, (at low current) so there can't be anything on that vcc line killing the voltage or you wouldn't have 9v. something is keeping the ic from oscillating.Last edited by R_J; 05-21-2022, 06:43 PM.Comment
On place D7950 i soldered SSL510 (SB5100 not yet in store)What do you have in place for D7950? Maybe disconnect whatever is in there and see if the vcc comes up.
The ic's startup cell IS providing the initial 9volts, (at low current) so there can't be anything on that vcc line killing the voltage or you wouldn't have 9v. something is keeping the ic from oscillating.Comment
Is that the right resistor wattage R7900? And you double checked that diode D7950 was installed right?Hello, please help me i have same problem on my Sharp Aquos 60LC635E No 5V power, tv dead . Blown R7900 and short D7950 . I changed it, than blown R7900 again . D7950 ok. I change IC7903 and cap on 5 leg 50V 47u and R7900 never blown again but 5V not( I do not know what to do . On big two cap 315V, on 5 leg IC7903 9V this very low for start A6069H . Datasheet say min 13V.
Please Help me. board power supply dps-162KP B RUNTKA932WJQZI assume no responsibility for any stupid suggestions I might post.Comment
I aquired this TV to attempt to fix. Found the R7900 open and D7950 diode shorted. Replaced both (5A diode only available) and this immediately popped IC7903 with a SNAP! Did the 5A diode cause this? There was nothing hooked to power board when it popped. I poked around some more and found D7904 looks to be shorted as well. I measured the pins on the T7901 and they all look good with no internal shorts across its individual windings. Where next? I saw where you can substitute a different style 5V regulator to the IC7903 with adding a resistor to one of the legs. I didnt check the SMD side for any damage, just a very quick repair of the 2 parts i initially found to be faulty.
Comparto mi experiencia, mi pantalla solo tenia los voltajes de stand by de 5v. Y mostraba un parpadeo corto y uno largo, al final encontre los leds da{ados y errores en la memoria de la main. Y tarde mucho por que crei que era error de los circuitos pfc; ya que les faltaba alimentacion al de pfc y el ncp.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
https://www.ebay.com/itm/116497313155?var=416785404161
Here are some of the description from the eBay seller
The main parameters:
1. Product name: High-power non-isolated DC boost module power supply.
2. Product model: 100A2000W.
3. Input voltage: DC12V-60V.
4. Input current: 100A (maximum).... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
