Sharp LC-60SQ15U TV DPS-167CP - No power
+ More Options
Posts
  • R_J
    • Jun 2012
    • 9583
    Re: Sharp LC-60SQ15U TV DPS-167CP - No power
    Originally posted by romasik
    7907 check his ok, on 4 legs 40mV
    Check for a shorted D7988, or defective PC7903, something is killing the feedback voltage. I suspect the voltage needs to be above 1 volt and maybe around 3~5 volts, but needs to be lower than 8 volts
    • romasik
      • May 2022
      • 56
      • Ukraine
      #62
      D7908 170 and 90 Omh
      • romasik
        • May 2022
        • 56
        • Ukraine
        #63
        What do you think?
        • R_J
          • Jun 2012
          • 9583
          What do you think?
          I think something is causing the voltage to be too low. If you look at the datasheet for the ic (page 11) you will see FB/OLP pin is supplied by approximately 7 volts, this line is controlled externally, so I suspect either the diode D7908 is bad or the optocoupler is bad.
          170Ω and 90Ω does seem to be low. lift one end of the diode and check again to see what the resistance is.
          • romasik
            • May 2022
            • 56
            • Ukraine
            #65
            Ok, i check later (it's too late, I'm going to sleep). How i can check IC7903 defective or not?
            • R_J
              • Jun 2012
              • 9583
              I would check the resistance and compare with the other two or try exchanging it with pc7904 and see if you get your standby voltage.
              You should be able to leave the zener diode out of circuit for testing.
              • romasik
                • May 2022
                • 56
                • Ukraine
                #67
                What is PC7904 ? And which diode should be soldered to test?
                • romasik
                  • May 2022
                  • 56
                  • Ukraine
                  #68
                  PC7904 i found, how check his?
                  • romasik
                    • May 2022
                    • 56
                    • Ukraine
                    #69
                    I checked diode D7908 57Omh and infinity , PC7904, PC7903 desolder and check all fine(
                    • R_J
                      • Jun 2012
                      • 9583
                      If the optocoupler and the diode are good, then it only leaves the ic that is bad.
                      If you look at the datasheet page 11, you will see that without anything connected to the FB pin, that pin should be at 7 volts. Normally the optocoupler controls this voltage and varies it around 3~4 volts to control the ic. You measured almost 0 volts on the FB pin. So something is keeping the voltage low or the ic is bad.
                      • romasik
                        • May 2022
                        • 56
                        • Ukraine
                        #71
                        is it possible to check ic somehow? in my city they are only in one store, it will be from the same batch.
                        How i can check my ic? Thanks
                        • romasik
                          • May 2022
                          • 56
                          • Ukraine
                          #72
                          and I also suspect the C7900, but I don’t understand how to check it with a multimeter. Like a regular cap, it does not show voltage after charging.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            #73
                            What is your ohm reading on R7900?
                            • romasik
                              • May 2022
                              • 56
                              • Ukraine
                              #74
                              R7900 is ok, I am writing about C7900
                              • R_J
                                • Jun 2012
                                • 9583
                                C7900 is likely good, If it was open circuit it will not stop the circuit from working. This cap is not your problem.
                                • romasik
                                  • May 2022
                                  • 56
                                  • Ukraine
                                  #76
                                  I no longer know what to do, maybe IC7903 is defective ? I also read on another forum that the voltage on large caps should be 380V with a working ic7801, and I have 300
                                  • R_J
                                    • Jun 2012
                                    • 9583
                                    You need the #$%%^ standby circuit working BEFORE the pfc circuit OR the main supply circuit will work.
                                    • romasik
                                      • May 2022
                                      • 56
                                      • Ukraine
                                      #78
                                      what to do? try to change IC7903 again?
                                      • R_J
                                        • Jun 2012
                                        • 9583
                                        Check the transformer winding between pins 4 and 5, it should be almost 0Ω, then check the resistors R7908,R7909,R7913, if they are good, check the diode D7904, also check the zener diode D7909
                                        If these are all good, Disconnect D7908 and pins 3&4 of the optocoupler PC7903 and see if the voltage on pin 4 of ic7903 comes up to about 7 volts. If it does not, I suspect the ic is bad.
                                        It is a simple circuit, and should not be that hard to diagnose.
                                        If you look at the schematic for the dps-262, you will see the pfc ic ic7801 pin8 gets it's VCC_ON voltage from the emitter of Q7902, The collector voltage is supplied via D7906/C7918. This voltage is only there when the standby circuit is working.
                                        • romasik
                                          • May 2022
                                          • 56
                                          • Ukraine
                                          #80
                                          transformer T7901 ? Why 4,5 ?
