PN59D6500FXZA Fast Track info incorrect
  • Ltank
    • Jun 2013
    • 776
    To test the BN96-16531A Logic Main PCB, the PDF tells you to short the highest two pins. If you look and ohm check they are shorted together because they are Gnd and they both measure 0 ohms to gnd. With that said I should short the bottom two pins?
    Pins 2 to 4? I have disconnected the cable to the M.B.
    Re: PN59D6500FXZA Fast Track info incorrect
    Can we see the fast track PDF? You are correct that those two pins on the top row as shown in the picture is tied to GND plane.
    • Ltank
      • Jun 2013
      • 776
      I jumpered pins 2 to 4. CN801 pin 1 PS_On was jumpered to pin 3 gnd.
      All P.S. voltages were good. Vs 217vdc, Va 55 vdc, Vsc-193 vdc and Ve 93 vdc.
      No Self Test Pattern? I would have thought that if all the voltages were good and the Logic board jumpered with the Control cable removed from the M.B. it should have worked. The Samsung video tell you to disconnect the the cable the PDF does not.
      Any Ideas where I went wrong?
      • Ltank
        • Jun 2013
        • 776
        I got it from Tom's website.
        • Ltank
          • Jun 2013
          • 776
          The words says top two the pic shows top to bottom on the left side of the four pins
          • Hamie
            • Apr 2014
            • 1383
            Btw for test patters its shorting pins 3 and 4
            • Ltank
              • Jun 2013
              • 776
              I put a Computer M.B. jumper across pins 3 and 4 still no test patterns. Control boars led 2000 blinks every second not indicating a problem with the Y or X boards. I am at a loss. Now.
              • Ltank
                • Jun 2013
                • 776
                On this TV the test patterns will work when the LVDS ribbon cable is connected to M.B. even though no power to it because I jumped the P.S. on. If the cable is disconnected there is no test patterns.
                Opposite of most instructions.
                • novice1
                  Acer Aspire E5-574G - Not Powering On
                  by novice1
                  Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
                  This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
                  To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
                  11-03-2023, 05:53 PM
                • jkucukov
                  Help with Samsung Microwave Cooling Fan Wiring Pins
                  by jkucukov
                  I have a Samsung Microwave I'm looking to harvest some parts from, specifically the 120V AC motor that keeps the Magnetron cool.
                  From the image below, we see 3 pins on the AC motor, with AC Voltage tester all 3 leads measure 120 V with the microwave plugged in and fan not running. With the fan running only pins 2 & 3 measure 120 V.
                  What I'm looking to do is wire this motor up on a Air Compressor to keep the motor cool, but I need to know what is the safe way to wire it, (IE wire in pins 2 & 3 with 120 V only to get it to run?)
                  Also, as its wired, when...
                  Today, 05:02 PM
                • corrize
                  Where to find a very small fpc connector 0.3mm between 2 pins ?
                  by corrize
                  Hello, I search this connector (oxydated).
                  It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                  I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                  I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                  Do you know how to find this connector please ? What is the exact name for find it ?
                  08-06-2024, 05:25 PM
                • cook
                  HP Power Supply 6632A: Fast Mode vs Normal Mode?
                  by cook
                  FAST MODE vs NORMAL MODE
                  I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
                  I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
                  06-07-2020, 05:32 AM
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
