Re: Coolant Leak on Mitsubishi WS-A65 CRT RPTV
When everything is connected and 9VS is jumping around do you have the 110V supply which is needed according to page3-4 of V20B chassis pdf.
It's part of the feedback loop controlling the transistor between pins 9,10 of the Opto which in turn increase or decreases the feeback to IC9A50.
P-on
Resistor R9A02 limits the input current prior to switch on.
When P-ON base goes high, the relay activates and s/c R9A02 (removes current limiter) and turns on led Pins 5,6 turning on Q9A50 which supplies 20V dc to the EN pin of IC9A50.
Once oscillation starts (minimum of 16V on EN pin to start) the voltage on En pin drops and is replaced with the rectified dc voltage from D9A54
Where does P-On gets its voltage from. Is there another power supply?Leave a comment:
ElectroStatic
If I'm tracing it right, it looks like it's going directly to the back of the box with the screen and electrostatic focus controls, where it is also fixed without an easy means of removal. That said, there's actually a bit of extra slack on it; enough that I could probably flip the board over in the set to do any necessary soldering (hopefully) without having to unplug that pesky cable at all. The position might not be optimal, but it could work. My main concern at this point is finding what is causing this weird fluctuating standby voltage problem.Leave a comment:
If its an EHT cable connected to one of the CRT's then it may well be that it can be unclipped from the tube.Leave a comment:
stand-by
I think so. On page 23 of the training manual, it says: (along with figure 4 attached to this post)
"D9A30 rectifies AC from a secondary winding of T9A20, generating a 9VS supply. This is the source for all standby supplies in the TV"
white wire goes down into the transformer, you cant desolder it - from that end anyway.
it runs at several KV so dont cut it - it's the focus or grid wire.Leave a comment:
So is the 9Vs the standby supply?Leave a comment:
standby voltage
As far as an external 9volt is concerned what would you recommend? Is that a good idea with the power supply doing strange things?Leave a comment:
With all the boards connected do you have all the other voltage that should be present, ie 110v, 206v,17v, 24v, -24v
Is the 9V secondary side loaded and bringing the supply down? Perhaps you could connect an external 9V at that point.
I cannot see how there could be such a high voltage across the opto diode unless the ground was floating. If the diode is not open circuit then it should clamp the voltage across it to between 1.2 1-1.6VLast edited by dick_barton; 07-22-2016, 02:42 AM.Leave a comment:
Troubleshooting data
You mean the white cable right? The white connector is to hold the cable in place!
I have not seen this before but just looking at that cable im sure it's shrink wire preventing either the cable showing the solder connections or for preventing something to get in/out.
You can always remove that shrink wire and add a new one later. My bet is that you will see some solder!. If it's permanently attached, I'll explore disconnecting it from the other end before cutting and splicing, but if it comes to that, I guess that's what'll have to be done.
I believe that Moreno83 is correct and it is probably soldered to the top of the transformer.
The schematic in post #6 shows a transformer giving 9Vs but in the photo post #7 it looks like a line output transformer used in CRT sets that provided the 10-30K for the crt tube?
Looking at your schematic post #6, D9A31 is an 8.2V zener and assuming you need 1.5V across the led of PC9A50 (pins 1 & 2) then total voltage = 9.7V and the zener should regulate the voltage to that approximate voltage.
Have you checked what dc voltage you have across the zener and the diode (pin1-2)Last edited by SurrealMustard; 07-21-2016, 05:37 PM. Reason: clarification of mainboard and signal board being disconnected for the testLeave a comment:
Have you checked what dc voltage you have across the zener and the diode (pin1-2)Last edited by dick_barton; 07-21-2016, 04:10 PM.Leave a comment:
Just had a look at the manual
Post #7 is the EHT transformer (T5A51)
I also believe that Moreno83 is correct and it's a sleeve that should pull upwards.
Can you unclip the lead from the other end which fits into the crt tube.Last edited by dick_barton; 07-21-2016, 04:01 PM.Leave a comment:
You can always remove that shrink wire and add a new one later. My bet is that you will see some solder!Leave a comment:
fluctuating 9 volt standby problems!
This is weird. With everything plugged up normally, 9VS is fluctuating between 2 and 8.5v randomly. Unplugging the signal board causes it to come up to fluctuating between 24 and 30 volts.
Specifically, I'm testing across D9A30 (as shown in the attached picture from the service manual), but it looks the same from any other 9VS test point in the set.
Any ideas?Leave a comment:
Re: Error resets
Is there an error reset that may need to be cleared because it detected a fault when the coolant leaked?Leave a comment:
Continuity and burns
Continuity is good on the pins close to the burn. And looking back at my footage from working on it days ago, the burn definitely wasn't there.Leave a comment:
Has the ribbon continuity where you have the burn mark? Are you sure that the burn mark wasn't already there due to heavy current passing through that connection wire prior to your repair.Last edited by dick_barton; 07-19-2016, 11:11 AM.Leave a comment:
by hugocarmoGood morning everyone.
This time I have a Mitsubishi HS-E82.
It was a bargain that I found with original remote included.
The problem reported by the owner is that it was working but no output video.
I took it appart and immediately saw that three 470uf capacitors were leaking on the signal board and one in the Hi-Fi board the same value too. I have located them in the pictures in red marker.
I replaced them, cleaned all the liquid remains and the video output got working again.
I saw too that were three surface mounted capacitors, two near the 470uf and... -
by sikocanLooking for a component labelled 56 on top 59 on bottom. It's from a MITSUBISHI ELECTRIC Air-Conditioner Network system. Thanks!...
by corrizeHello, I have a basic power board (from DSLR camera), this board convert 12v in some other voltages (there is no charging chip). This board is disconnected to other, so it feed nothing, the outputs should be open lines.
When I plug the battery (12v), I measure a weird behavior…
I found a mosfet , with 12v at source and gate, and the voltage decrease very slowly at drain : 8v… 7v… 6v… I measured with meter source-drain : 45KOhms, so can I deduce surely the mosfet has a leak (and it is dead) pls ?
The mosfet datasheet, but it's basic one.
https://pdf1.alldatasheet.co... -
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... -
by cloudff7there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
Channel: General Capacitor Questions & Issues
- Loading...
