Yep, got a CRT rear projection HDTV to work on. Basically, after transporting it, fixing the cold solder joints on the convergence ICs, and cleaning the lenses, I got it all put back together and everything worked great for about two days. I had just ascertained a non-malfunctioning Xbox 360 to put this thing through its paces and was all ready to get started, but when I pushed the power button on the set, it just clicked right off and started blinking the power light. Removing and restoring power has not changed the condition and holding "menu" and "input" does not provide any kind of an error code.
Before I go any further, I need to clarify that this is not one of the digital Mitsubishis with the DM that always breaks down and causes the "blinking green light of death".
Anyway, I cracked it open this morning and found that coolant had inconveniently dripped from the red tube onto one of the white ribbon connectors going between the mainboard and the power supply (first two pictures). After removing the board and thorougly cleaning it up (third picture showing burnt, but clean, ribbon), I was hoping that it might be fixed, but it is unfortunately still doing the same exact thing. Further inspection of the rest of the set has revealed no other obvious coolant leaks or stains.
Any ideas as to where to troubleshoot next?
(If it helps, the "WS-A65" is one of the V20B chassi models (similar to a WS-65311).)
Coolant Leak on Mitsubishi WS-A65 CRT RPTV
by hugocarmoGood morning everyone.
This time I have a Mitsubishi HS-E82.
It was a bargain that I found with original remote included.
The problem reported by the owner is that it was working but no output video.
I took it appart and immediately saw that three 470uf capacitors were leaking on the signal board and one in the Hi-Fi board the same value too. I have located them in the pictures in red marker.
I replaced them, cleaned all the liquid remains and the video output got working again.
I saw too that were three surface mounted capacitors, two near the 470uf and... -
by sikocanLooking for a component labelled 56 on top 59 on bottom. It's from a MITSUBISHI ELECTRIC Air-Conditioner Network system. Thanks!...
by corrizeHello, I have a basic power board (from DSLR camera), this board convert 12v in some other voltages (there is no charging chip). This board is disconnected to other, so it feed nothing, the outputs should be open lines.
When I plug the battery (12v), I measure a weird behavior…
I found a mosfet , with 12v at source and gate, and the voltage decrease very slowly at drain : 8v… 7v… 6v… I measured with meter source-drain : 45KOhms, so can I deduce surely the mosfet has a leak (and it is dead) pls ?
The mosfet datasheet, but it's basic one.
https://pdf1.alldatasheet.co... -
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... -
by cloudff7there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
Channel: General Capacitor Questions & Issues
- Loading...
