So I have a Sony KDL‑60EX700 60" Bravia, gotten it for free. When I had gotten it, it had a flash code, so I replaced the power board. Then another flash code, and I replaced the main board. Now I have power to the t.v., I have tried to install the new firmware (nothing shows up on the screen) in the hopes that it'll be fine. It wont go into standby mode, and none of the buttons above the switch seem to do anything. Any suggestions?
Sony KDL‑60EX700 Black Screen w/power
Re: Sony KDL‑60EX700 Black Screen w/power
So no more error codes, and what were the codes before?
Pictures of the whole back side of the TV showing all the boards so we can see what we are dealing with.
Was it worked on by someone else before you got the TV? Any history of what happened to the TV?Never stop learning
No more error codes. There was some work done prior, they replaced the main board, but put the old one back in then I was able to obtain it after that. There was 5 flashes when I got it, so I replaced the power board thinking they kept the main board in. I turned it on and the light was green for a moment or 2, then it flashed several times at me, then I was able to get the main board they used and I installed it. Turned it on and I have a solid green light but no picture. Little did I know I had to have a thumb drive to try to install firmware on it, so I tried 2 or 3 different thumb drives around the house and nothing, so I ordered a Sony thumb drive and formatted it to FAT32 and put the firmware on it for the t.v.
As far as pictures go, I have the backing on the t.v. this has been an on going project (about 2 months at this point) due to various reasons. If it is absolutely necessary for help, I will remove the backing and take pictures, but I'd rather not.
History for this t.v. as I was told is that it would shut off randomly.
Seems to be a power board issue. Please take pictures of the back and show them individually. It's open anyway, right?
Originally posted by Vegink View PostNo more error codes. There was some work done prior, they replaced the main board, but put the old one back in then I was able to obtain it after that. There was 5 flashes when I got it, so I replaced the power board thinking they kept the main board in. I turned it on and the light was green for a moment or 2, then it flashed several times at me, then I was able to get the main board they used and I installed it. Turned it on and I have a solid green light but no picture. Little did I know I had to have a thumb drive to try to install firmware on it, so I tried 2 or 3 different thumb drives around the house and nothing, so I ordered a Sony thumb drive and formatted it to FAT32 and put the firmware on it for the t.v.
But first test the t-con u need to take apart the plates that is covering the tcon.....once you get to the tcon... disconnect one side of the 2 ribbons going to the screen you going to leave one connected and then turn on TV and see if theresults video on one side If not try the other side....connect one and leave one disconnected.
So as I've said before, this has been a long process and my wife reminded me of a detail I forgot about. Let me revise the history: So as I was told it would shut off randomly. They bought a new main board and tried to replace it, they said it didn't work, they took it to a repair shop and they said it would need a new screen. When I got it, it still turned on, but there were flash codes. I then replaced the power board and main board. I can still check the tcon and the tabs.Last edited by Vegink; 08-17-2016, 09:06 AM.
Ok, so I took a closer look to see if all the wiring was plugged in, and I noticed I had not plugged one in well, so I fixed it and now I have a green and yellow flashing light on the front of the t.v.Last edited by Vegink; 08-18-2016, 09:11 AM.
