Sony KDL‑60EX700 Black Screen w/power
  • Vegink
    • Jul 2016
    • 14
    Re: Sony KDL‑60EX700 Black Screen w/power
    Any suggestions?
    • Vegink
      • Jul 2016
      • 14
      Any help?
      • budwich
        • Jul 2015
        • 3097
        Originally posted by Vegink
        Any suggestions?
        did you try this suggestion ????
        "But first test the t-con u need to take apart the plates that is covering the tcon.....once you get to the tcon... disconnect one side of the 2 ribbons going to the screen you going to leave one connected and then turn on TV and see if theresults video on one side If not try the other side....connect one and leave one disconnected."
        if you don't follow the suggestion that people give you, you are going to have limited success both at fixing and getting further help.
        • Vegink
          • Jul 2016
          • 14
          I did not, because when the situation changed, then so should the advice. You wouldn't change the spark plugs on a car for a flat tire.
          • budwich
            • Jul 2015
            • 3097
            good luck... having fun watching your black screen... wait the situation has changed... NOT.
            • Vegink
              • Jul 2016
              • 14
              If you go to the doctors for a cold, they will treat you for a cold because you show those symptoms. But if you end up going home and start experiencing organ failure, you don't continue the same treatment for a cold. I've added a new issue to my situation, so you can not expect the same results by messing with the icon board, when I reconnected the wires and got 2 flashing lights, which is new compared to when it was being suggested that I mess with the tcon board.
              • grimacelord
                HP 15-EH1070wm - Black Screen With Power LED.
                by grimacelord
                I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                01-28-2023, 10:50 AM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • rybby
                Acer Aspire 5 A515-51 power on but black screen
                by rybby
                I have an acer aspire 5 a515-51 that turns on but has a black screen.
                This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
                Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
                06-16-2023, 09:41 AM
              • burntonnerings
                Acer K272HUL blue power light but black screen, power supply is ok
                by burntonnerings
                Have had two Acer K272HUL monitors die with the same symptoms:
                - Blue power light is illuminated while the monitor is plugged in
                - Black screen (no splash screen, etc.)
                - Power button doesn't do anything
                Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
                Power supply voltages are fine.
                There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
                Anyone have any ideas?...
                12-09-2023, 10:22 PM
              • Adam Russ
                Black screen on Sony 65x90ch (65x900h from Costco)
                by Adam Russ
                Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                09-15-2024, 05:46 PM
