Sony KDL‑60EX700 Black Screen w/power
  • Vegink
    • Jul 2016
    • 14
    So I have a Sony KDL‑60EX700 60" Bravia, gotten it for free. When I had gotten it, it had a flash code, so I replaced the power board. Then another flash code, and I replaced the main board. Now I have power to the t.v., I have tried to install the new firmware (nothing shows up on the screen) in the hopes that it'll be fine. It wont go into standby mode, and none of the buttons above the switch seem to do anything. Any suggestions?
    Re: Sony KDL‑60EX700 Black Screen w/power
    So no more error codes, and what were the codes before?
    Pictures of the whole back side of the TV showing all the boards so we can see what we are dealing with.
    Was it worked on by someone else before you got the TV? Any history of what happened to the TV?
    • Vegink
      • Jul 2016
      • 14
      No more error codes. There was some work done prior, they replaced the main board, but put the old one back in then I was able to obtain it after that. There was 5 flashes when I got it, so I replaced the power board thinking they kept the main board in. I turned it on and the light was green for a moment or 2, then it flashed several times at me, then I was able to get the main board they used and I installed it. Turned it on and I have a solid green light but no picture. Little did I know I had to have a thumb drive to try to install firmware on it, so I tried 2 or 3 different thumb drives around the house and nothing, so I ordered a Sony thumb drive and formatted it to FAT32 and put the firmware on it for the t.v.
      As far as pictures go, I have the backing on the t.v. this has been an on going project (about 2 months at this point) due to various reasons. If it is absolutely necessary for help, I will remove the backing and take pictures, but I'd rather not.
      History for this t.v. as I was told is that it would shut off randomly.
      • Vegink
        • Jul 2016
        • 14
        Anyone else willing to try to assist?
        • hmendez86
          • Jun 2015
          • 344
          • united states
          What's the problem with tv....I fix 60ex645 black screen and it powers no no image just sound....it's a panel problem but it's 50/50 fix or death tv...need Info about your tv problem and pics
          • orinoco8
            • Jan 2016
            • 26
            Seems to be a power board issue. Please take pictures of the back and show them individually. It's open anyway, right?
            • Vegink
              • Jul 2016
              • 14
              Sorry it took so long to get these photos, let me know if I need any other specific ones.
              • hmendez86
                • Jun 2015
                • 344
                • united states
                The problem is with the driver tabs
                • hmendez86
                  • Jun 2015
                  • 344
                  • united states
                  Do not not not do the firmware update until you get image....if the tv powers on, including power supply and main board you good next you need to test the t-con if it's working
                  • Vegink
                    • Jul 2016
                    • 14
                    Where are the driver tabs?
                    • hmendez86
                      • Jun 2015
                      • 344
                      • united states
                      The driver tabs are attached on the screen glass on the left and rigth it should have 3 on each side...you need to removed the bezel from the tv.
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        But first test the t-con u need to take apart the plates that is covering the tcon.....once you get to the tcon... disconnect one side of the 2 ribbons going to the screen you going to leave one connected and then turn on TV and see if theresults video on one side If not try the other side....connect one and leave one disconnected.
                        • Vegink
                          • Jul 2016
                          • 14
                          So as I've said before, this has been a long process and my wife reminded me of a detail I forgot about. Let me revise the history: So as I was told it would shut off randomly. They bought a new main board and tried to replace it, they said it didn't work, they took it to a repair shop and they said it would need a new screen. When I got it, it still turned on, but there were flash codes. I then replaced the power board and main board. I can still check the tcon and the tabs.
                          • hmendez86
                            • Jun 2015
                            • 344
                            • united states
                            Ok check as I told you before disconnect one side and leave one connected to see if there picture on one side of the tv....add pictures of what u doing....
                            • hmendez86
                              • Jun 2015
                              • 344
                              • united states
                              Forget what the repair man told you and old owner told you....so were we are. that your tv is working but no video or its doing the blinking codes..
                              • hmendez86
                                • Jun 2015
                                • 344
                                • united states
                                The blink codes is because of the panel, but 50-50 we can get it to life again.
                                • Vegink
                                  • Jul 2016
                                  • 14
                                  Ok, so I took a closer look to see if all the wiring was plugged in, and I noticed I had not plugged one in well, so I fixed it and now I have a green and yellow flashing light on the front of the t.v.
                                  • Vegink
                                    • Jul 2016
                                    • 14
                                    Any suggestions?
                                    • hmendez86
                                      • Jun 2015
                                      • 344
                                      • united states
                                      Post pics of how it looks.
                                      • Vegink
                                        • Jul 2016
                                        • 14
                                        Here is the picture.
                                        • grimacelord
                                          HP 15-EH1070wm - Black Screen With Power LED.
                                          by grimacelord
                                          I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                                          First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                                          01-28-2023, 10:50 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • burntonnerings
                                          Acer K272HUL blue power light but black screen, power supply is ok
                                          by burntonnerings
                                          Have had two Acer K272HUL monitors die with the same symptoms:
                                          - Blue power light is illuminated while the monitor is plugged in
                                          - Black screen (no splash screen, etc.)
                                          - Power button doesn't do anything
                                          Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
                                          Power supply voltages are fine.
                                          There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
                                          Anyone have any ideas?...
                                          12-09-2023, 10:22 PM
                                        • rybby
                                          Acer Aspire 5 A515-51 power on but black screen
                                          by rybby
                                          I have an acer aspire 5 a515-51 that turns on but has a black screen.
                                          This laptop has the same symptoms as https://www.badcaps.net/forum/showth...er+aspire+a515, however mine is a different model Acer Aspire A515-51 (without the 'G'). There is no onboard ram on this laptop.
                                          Description of the problem is the same: I press the power button, the fan spins for a few seconds and then stops, the computer stays on all the time (led blue), the cpu and gpu are lukewarm. If I leave the pc on for a few minutes the fan starts...
                                          06-16-2023, 09:41 AM
                                        • Adam Russ
                                          Black screen on Sony 65x90ch (65x900h from Costco)
                                          by Adam Russ
                                          Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                                          09-15-2024, 05:46 PM
