Maxent MX-50HPT52 has a shaky picture (video inside)
  • vizi0n
    • Nov 2014
    • 28
    my 50" plasma tv has a shaky picture. It seems like portions of the content are shifted up/down randomly. It does that on every input. Even the menu is affected by this.
    Every board inside this thing is made by Samsung.
    Here is a Youtube video : https://www.youtube.com/watch?v=g1cu_vUBDkk
    Do you have any suggestion about where to start looking? I checked for leaky/bulged caps but they all seem clean.
    Thanks!
  • vizi0n
    • Nov 2014
    • 28
    Re: Maxent MX-50HPT52 has a shaky picture (video inside)
    Some more info:
    Everything was shaky (menu and picture). After changing the logic board (LJ41-03703A) the overlay menu is not shaky anymore but some rows of pixels (1 pixel high) seem like their content is shifted a few pixels to the right, but not beginning at the left side, more like a few inches away from the left side.
    The picture is still horrible on all live inputs.
    Y-Main : LJ41-04084A
    Y-Buffer (up) : LJ41-03882A
    Y-Buffer (low) : LJ41-03883A
    The overlay menu is somewhat fine on a source with no input, but some pixel rows seem like they have their pixels a bit shifted to the right (by 2-3 pixels). If I switch to a "live" input, the menu is unusable and very dark.
    Any leads? Thanks
    New Youtube video : https://www.youtube.com/watch?v=p9fozwGNVyw
    • vizi0n
      • Nov 2014
      • 28
      The voltages on the 10 MOSFETs on the Y-Main are pretty unstable (they vary all the time by about 8-10v on every leg, all of them). Is this a normal behavior?
      The 8 diodes are operating normally (flow only in one way)
      Every voltage test points (VScan, etc) have all been adjusted to specs according to the number on the label and are very stable at the power supply, and when they enter the Y-Main
      • vizi0n
        • Nov 2014
        • 28
        Bump ... anyone?
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Do you have clear pictures of your boards and the interconnections.
          • vizi0n
            • Nov 2014
            • 28
            Here, I have attached photos of the boards.
            Sorry if its not very clear, I have a shitty lighting in my home workshop
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              The logic control board is half hidden by the metal chassis. Can you see what the part number is.
              • vizi0n
                • Nov 2014
                • 28
                It is the first thing I've changed last week. It is LJ41-03703A
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  May be worth while trying to run the test patterns to see if the fault lies with the mainboard:
                  Power off
                  Disconnect the LVDS cable going to the mainboard
                  Connect the 2 holes marked Ext_Auto_gen with a bit of wire, paperclip etc.
                  Plug in the tv and turn it on.
                  Edit
                  I see they are marked 1,2,3 & 4
                  Not sure which two to jumper.
                  Will look further
                  • vizi0n
                    • Nov 2014
                    • 28
                    The only thing I could get was a full white picture when shorting 2 of the pins. The switch on the board would not do anything while in test mode.
                    Is that what I should be getting?
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      With the cable disconnected from the mainboard and I believe pins 3 &4 shorted then when you switch back on you should have a screen showing a series of colours or patterns in one after the other. ie, red, green, white, blue etc
                      https://www.badcaps.net/forum/showth...ght=tom+plasma
                      There is some info on Samsung control board in this thread
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Sounds like a bad motherboard to me, the control boards for these sets are quite reliable tbh. Try what DB suggested to help confirm might even be something simple like lose or dirty Lvds cable.
                        • vizi0n
                          • Nov 2014
                          • 28
                          Is the LVDS cable the one that goes to the board with all the inputs?
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            Thats the one. The black cable with the multicoloured wires at the end. Remove the connector carefully.
                            • vizi0n
                              • Nov 2014
                              • 28
                              With legs 3/4 shorted with a jumper and LVDS cable disconnected :
                              when I turn on the tv I only have a full white picture. The switch (SW2000) doesn't change the pattern on the display)
                              Large picture of the board available here : https://spares2repair.co.uk/samsung-...sic-logic-main
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                Here's a video which may be worth following to see if it will bring up the test pattern.
                                https://www.youtube.com/watch?v=JjrwTZC5nVg
                                • vizi0n
                                  • Nov 2014
                                  • 28
                                  I did all the same tests that are shown in this video. Voltages are good, but I always get the full white picture when jumping 3 and 4 (even when bypassing ps_on) I see that in the video they are actually jumping 3 and 1 so I tried that, but it boots normally.
                                  LED2001 lights up solid while booting, then LED2002 starts flashing rather quickly and LED2001 shuts off.
                                  Youtube video: https://www.youtube.com/watch?v=5UyzvjLCABk
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Replace the mainboard then is what I would do or find a way to factory reset it.
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      I'm out of ideas so would do as ReeceyBurger123 suggests.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Well looking at the video its deffo a Lvds processing fault, if it was a control board fault on the full white screen it would be messing up.
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                        • hugocarmo
                                          Grundig GV-250 Repair problem. (Video inside post)
                                          by hugocarmo
                                          Hi everyone.
                                          I have the following problem.
                                          I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
                                          In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,...
                                          01-19-2023, 06:46 AM
                                        • gl4709
                                          Samsung un55cu7000d with backlight and sound No Video / Picture
                                          by gl4709
                                          I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                                          01-23-2025, 06:21 PM
                                        • Ierwin
                                          Philips 58PUS7805 Menu working but no/weird picture from video sources
                                          by Ierwin
                                          I got a 58pus7805 that shows some weird behavior.
                                          The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                                          However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                                          I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                                          I managed to install the latest official firmware by holding the control button while plugging...
                                          03-10-2024, 12:50 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
