Maxent MX-50HPT52 has a shaky picture (video inside)
  • vizi0n
    • Nov 2014
    • 28
    Re: Maxent MX-50HPT52 has a shaky picture (video inside)
    So you suggest replacing the board with the inputs? That is the mainboard, correct?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Yes, keep us updated.
      • vizi0n
        • Nov 2014
        • 28
        Okay thanks.
        I will wait until I find one of the correct P/N. There are many B.ZRAT3C variants and this tv has the B.ZRAT3C-2 7355.
        I wonder if the other ones would work as well, because they all have the same connectors (or more), and same components (or more).
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Its best to match a board with all the same numbers as others could be for different screens with different resolutions.
          • vizi0n
            • Nov 2014
            • 28
            Better late than never, but thanks for your input/help. I have finally managed to find a spare main board last week on Ebay and received it today. Tv works like new!
              HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
              This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
              09-12-2024, 02:00 PM
            • gl4709
              Samsung un55cu7000d with backlight and sound No Video / Picture
              by gl4709
              I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
              01-23-2025, 06:21 PM
            • hugocarmo
              Grundig GV-250 Repair problem. (Video inside post)
              by hugocarmo
              Hi everyone.
              I have the following problem.
              I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
              In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,...
              01-19-2023, 06:46 AM
            • Ierwin
              Philips 58PUS7805 Menu working but no/weird picture from video sources
              by Ierwin
              I got a 58pus7805 that shows some weird behavior.
              The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
              However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
              I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
              I managed to install the latest official firmware by holding the control button while plugging...
              03-10-2024, 12:50 PM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
