RCA 40LA45RQ Power issue, standby on
  • leftyz
    • Jun 2016
    • 6
    Got this TV set from my Dad, he replaced it with a new Sony Bravia so I figured I'd try to get it working.
    Typical no power on situation, red standby light stays on.
    Only thing that makes this a little different, that I havent seen mentioned elsewhere is if you leave it unplugged for several minutes, then plug it back in the set will turn on, and work for about 3-5 minutes, sometimes more sometimes less, then you hear multiple pops/clicks from the speakers and it shuts itself off (blue power LED turns back to red) and after that it will not turn back on unless you unplug it and do that whole dance again.
    I replaced the power board since it was only $16 on eBay, now looking at the main board since the issue didn't get resolved. What is the best procedure for testing to make sure I'm replacing the correct parts?
    Thanks All, I appreciate the help
    Re: RCA 40LA45RQ Power issue, standby on
    Shopjimmy sells EEPROM so that may be the problem. Did you try cooling the EEPROM using canned air duster upside down to get the coolant out for cooling?
    http://www.shopjimmy.com/catalogsear...q=RCA+40LA45RQ
    BTW, pictures of the whole back side of the TV to show all the boards will help.
    • CapLeaker
      Leaking Member
      • 8296
      there are many main boards for that TV. You need to check what mainboard you got and select the correct EEPROM IC. As budm said, SJ has them.
      • leftyz
        • Jun 2016
        • 6
        Thanks guys, EEPROM it is... (Unless my main board is one I can get for like $30, lol)
        • leftyz
          • Jun 2016
          • 6
          40RE01TC711LNA0-A1, found several boards and the EEPROM, not confident in my soldering skills so trolling fleabay for the lowest price, thanks guys.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Keep us updated.
            • leftyz
              • Jun 2016
              • 6
              Absolutely, here are the photos I did take today
              • leftyz
                • Jun 2016
                • 6
                Got a main board for $46 shipped on eBay. Just hookup and running about 10 mins no hiccups, think it may be fixed!
                • CapLeaker
                  Leaking Member
                  • 8296
                  A1!
                  • justice171
                    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                    by justice171
                    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                    1. Verified that all critical voltages are present:
                      • 3.3V and 5V are always present if DC is plugged.
                      • 1.8V on the BIOS chip is present.
                    2. Checked the power button functionality:
                      • When pressed, the voltage drops to 0V, indicating the button is functional.
                    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                      • Confirmed connectivity is intact, ruling out issues
                    11-26-2024, 12:39 AM
                  • claws77
                    lenovo flex 5 14itl05 power sequence issue
                    by claws77
                    hi guys, my motherboard will not start no matter what
                    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                    but rest nothing happens no sign of life.
                    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                    i have no knowledge of motherboards ....
                    10-20-2024, 02:48 PM
                  • yaya3gmax
                    Laptop Power Issue – Works on Battery, Fails on Adapter Load
                    by yaya3gmax
                    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                    Symptoms:
                    • Laptop works normally on a pre-charged battery.
                    • Battery does not charge when adapter is connected.
                    • Without battery:
                      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                      • Speakers “pop” when power cut occurs indicating harsh sutdown.
                      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                    08-21-2025, 07:16 AM
                  • YOUCEF4787
                    Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                    by YOUCEF4787
                    I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                    Initial Problem:
                    The laptop was completely dead, no signs of life, no power LED.
                    Action Taken:
                    I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                    Current Situation & The Main Issue:
                    The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                    Today, 12:19 PM
