Vizio e500i-b1 won't turn on
  • Twithers
    • May 2013
    • 69
    • U. S.
    I've got no activity from the tv at all. I opened it up and I hear a faint, high pitched squeal, alternating with a click sound. Squeal, click, squeal, click........ Coming from the power board. This happens as soon as the power cord is plugged in. Pushing the power button has no effect on the noise. Weirdly, when I unplug the harness that runs from the power board to the main board the noise stops.
    I checked for voltages at the plug on the power board where the main board would plug in. I get 5v, but no 12v or 24v.
    What do you think?
    Thanks.
    Re: Vizio e500i-b1 won't turn on
    You can start by uploading good clear pictures of the whole backside of the TV so we can see all the boards and how they are connected together.
    We need to check the DCV on the power supply board that goes to the main board to see what Voltages and signals are missing from the board.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • brzostos
      HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
      by brzostos
      Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
      After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
      Original HP 150W power supply, the diode in the power socket lights...
      10-01-2024, 01:34 AM
    • afdreher
      Vizio M60-C3 won't turn on. Is it the main board?
      by afdreher
      Hi, I've been stalking the site trying to diagnose the problem with my Vizio M60-C3. When turned on, the screen remains black and there is no audio. There is nothing displayed on the screen using the flashlight test, but the status light does illuminate and the optical audio out port does illuminate. The symptoms are almost identical to https://www.badcaps.net/forum/showthread.php?t=51443.
      On the power supply board (60CAP090), with the TV off, everything reads ~0V except for the two +12V rails (pins 8 & 9 on the connector the main board (CN201)), which read 12.57V, and the AC-DET...
      05-22-2020, 02:06 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
