Philip 42PFL5609/98 - Intermittent
  • wushumike
    • Jun 2016
    • 41
    • singapore
    The TV is giving intermittent problem as follows:
    1) Stay in standby mode (red color indicator) and will not responds to the remote or power switch on the TV....Have to unplug and replug in supply multiple time and with luck will turn on.
    2) When turn on (white color indicator) it will operate and suddenly there will be a glitch and the display goes haywire and speaker clutters....following will not be responding to remote ...have to power down again.
    3)At time, from standby mode, pressing the remote will switch on (white indicator) but no picture or sound......again will not response to the remote.
    Test Done so on PS board - measurement
    a) PIC 1 : with standby light
    b) PIC 2 : switch from standby to white light but no display
    c) PIC 3 : when TV is working
    I have remove and tested all the thru-hole capacitor and the reading are all OK.
    Not sure if it is the Power Supply or Main board that is giving the problem... If it is the main board, how to or is it possible to rectify and repair.
    Attached Photo :
    ps measured point with cable connected to main board
    PS Board Part No : 40-T8222P-MAD2XG
    Seeking all the experts advice....
    Rgds
    Wushumike
    Re: Philip 42PFL5609/98 - Intermittent
    Can we see the pictures of the whole boards?
    Right now it looks like the main board is the problem.
    • wushumike
      • Jun 2016
      • 41
      • singapore
      Hi BUDM
      Here is the photo of the ps and main board.
      Oh btw i made a mistake the ps part no should be 40-IP42PS PW11XG
      The main board is 40-T8222P-MAD2XG
      Rgds
        https://www.badcaps.net/forum/attach...0&d=1467222411
        Unplug the TV from the AC outlet then heat up the main board, especially on the that metal shield where the processor is with hair dryer for 3~4 minutes, then plug the TV into the outlet and see if it will start properly.
        • wushumike
          • Jun 2016
          • 41
          • singapore
          Hi BUDM
          Have already tried using hair dryer (hot air) blowing to heat up the ps. Board and main board....The problem still persist.
          I thought I could simulate/isolate the faulty area... but did not workout.
          Rgds
          • wushumike
            • Jun 2016
            • 41
            • singapore
            This is the glitch screen im talking about.
              Well, the problem is on the main board some where, I have no idea where, there are some 3-pin regulator ICs on the main board that I can see from the pictures that you can check.
              • Diah
                • Feb 2013
                • 6397
                yours Philips working with out any error code, this is one of stand by firmware issue.. which are in this early model chassis TCM3.2A of PFL5X series not able to upgrade it via USB, but there are working around you can try, here you have the service manual of this chassis TCM3.2A
                • wushumike
                  • Jun 2016
                  • 41
                  • singapore
                  Yes Diah,
                  Remember that I downloaded and updated the software via USB some year back...then the TV operate without any problem.
                  Anyway, I downloaded the version from Philip and reload it to the TV again although it was reported by the system that the version is the same.
                  I have also measured the voltages of the main board regulator when the TV is working and all the voltages seems normal...attached picture of reading.
                  Thanks for the schematic....but I don't know how to work around the problem if it is due to software.
                  • Diah
                    • Feb 2013
                    • 6397
                    with yours photo of Firmware update, yours Pfilips should work Picture and sound with HDMI digital signal.. plug video source to HDMI 1 and post here photo please.
                    • wushumike
                      • Jun 2016
                      • 41
                      • singapore
                      Nope...as mentioned only if I can get the tv to startup.
                      The problem is illusive....sometime no standby light at all, at time with standby light and when press remote, LED turn which but no display.
                      The thing is that even if I manage to get the TV to startup after multiple unplug and plug the supply.....there will happen when the screen suddenly go haywire and speaker starts cluttering with noise.
                      There are also times when the tv startup and suddenly restart again ....but system hang.
                      Even when the tv is not working properly, I did a measurement on the main board regulators output....the supply actually did turn on as I was getting 2.68V , 1.2V, 5V, 3.3V .
                      At least with all helps, it has been narrowed down to the main board problem and not the power supply board.
                      My TV mother board partnumber is 40-T8222P-MAD2XG 42PFL5609/98
                      I did a goggle search for the board and found selling
                      40-T8222P-MAD2XG 42PFL5609/93
                      Not sure /98 and /93 what is the different..... If I were to get the /93 is it compatible to my TV model
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Edit
                        Just thinking about this:
                        Is it possible that 98 and 93 are being misread?
                        • wushumike
                          • Jun 2016
                          • 41
                          • singapore
                          Hmmmm....
                          I attach my tv mb photo and taobao snapshot...
                          Eeee... initially I thought was the year...but 93 is just too old
                          • Diah
                            • Feb 2013
                            • 6397
                            /98 & /93 same chassis TCM3.2A and pin layout passed
                            • Diah
                              • Feb 2013
                              • 6397
                              however this not official repair methods , and you are going to buy replace MB, why dont try to heat your kitchen Often to 250 degree ( No air reflow heat ) and place the MB for 5-10 minute then just open the often door and never move the MB till it cool down, and check.
                              • wushumike
                                • Jun 2016
                                • 41
                                • singapore
                                Yap agree...Just googling around....
                                I have removed the aluminium shield to take a look at the processor area...no dry joint or bloated cap...I have also use the same heat blowing method.but problem still remain.
                                As the fault is intermittent...I really have no ideal what is wrong...
                                Frm the schematics, there is this standby mode processor...could this fail?..but then there are firmware burn into the processor...so no way to replace .
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Do you kmow anyone who could reflow the board for you as Diah suggests?
                                  • wushumike
                                    • Jun 2016
                                    • 41
                                    • singapore
                                    Nope..I got no resource for IR reflow.
                                    I will try Diah method of burn-in today to see if any good.
                                    Will update status.
                                    • cstout
                                      DeLonghi AC Remote only accepts 3V
                                      by cstout
                                      Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                      The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                      I can't find any schematics...
                                      06-03-2024, 03:53 PM
                                    • tvguy12012012120
                                      by tvguy12012012120
                                      02-07-2025, 05:13 PM
                                    • Mc_Millian
                                      Toshiba 50lf711u20 fire tv remote not pairing
                                      by Mc_Millian
                                      I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                      The Tv model number is: 50lf711u20 Rev B.
                                      I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                      I've tried 3 different remotes which should be fully compatible with this TV.
                                      Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                      The power button, along with the volume,back,select, and directional...
                                      04-07-2022, 12:15 PM
                                    • edugimeno
                                      HiSense 55A7500F won't obbey to remote after power on
                                      by edugimeno
                                      Hi! I have this TV set that does the following:
                                      1) I press the red power button on the remote
                                      2) The TV turns on normally
                                      3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                      4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                      Then after it's off, it would again accept the TURN ON from the remote and same again
                                      BUT:
                                      -The remote does show the correct IR beam while observed thru a phone camera
                                      -The TV works fine while using the MiRemote...
                                      03-14-2023, 11:22 AM
                                    • tmhobadcap
                                      Pioneer VSX-522-K remote control not working???
                                      by tmhobadcap
                                      I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                      At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                      12-24-2020, 01:44 AM
