kdl-60ex645 mainboard change to KDl-50ex645 update problem
+ More Options
Posts
  • hmendez86
    • Jun 2015
    • 344
    • united states
    I have KDL60EX645 THE ORIGINAL MAINBOARD WAS DAMAGE AND SAW THIS KDL-50EX645 MAIN FOR CHEAP AND IT REVEAL THAT IT'S COMPATIBLE WITH THE ORIGINAL ONE. IT STATED IT NEEDS UPGRADE...I ALREADY DID TRY TO UPDATE BUT IT'S THE SAME UPDATE I DOWN LOADED FROM SONY SUPPORT AND THERE'S NO OTHER UPDATE...what can I do...do I get to service mode ?????and yes I got picture with the kdl50ex645 but its not on normal view it's like pixel..
  • mmartell
    • Oct 2013
    • 3189
    Re: kdl-60ex645 mainboard change to KDl-50ex645 update problem
    Swap the eeproms..
    Last edited by mmartell; 06-28-2016, 03:27 AM. Reason: tried to type in caps, damn.
    • hmendez86
      • Jun 2015
      • 344
      • united states
      But in this sets were the eeprom is located
      • mmartell
        • Oct 2013
        • 3189
        Post pictures of the board.
        • hmendez86
          • Jun 2015
          • 344
          • united states
          • hmendez86
            • Jun 2015
            • 344
            • united states
            This is the original board...took the metal off to see were is the eeprom...
            • Diah
              • Feb 2013
              • 6376
              yours original are 60 and the new are 50 just go inside service menu and change panel size, panel serial no, . as well the Model name... you will be fine.
              • hmendez86
                • Jun 2015
                • 344
                • united states
                Yes from 60ex645 to 50ex645....how do I get to service mode....do I need original remote....
                • Diah
                  • Feb 2013
                  • 6376
                  i am not sure if this work on yours model too, try this
                  put the TV in stand by mode, then with remote Press “i+ (info)”, “5”, “Volume +” then “TV power” on, You can see Service Mode on display
                  to active rewrite date mute, 0
                  to navigate 1,2,3,4
                  change value 1 increase 4 decrease
                  be cafull . suggest you take photo first on each page you try to change to go back as default if need later.
                  • hmendez86
                    • Jun 2015
                    • 344
                    • united states
                    Well it worked with the display, 5, volume up and power on. I just went down on the menu and change from 50 to 60.....and I notice the change it now have nice picture..is it normal the red and green ligth are on at the same time while the tv is running normal....
                    • hmendez86
                      • Jun 2015
                      • 344
                      • united states
                      • Diah
                        • Feb 2013
                        • 6376
                        good, if you change channel with remote control, which led blinking with the command ?
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          one of the lights is power saving mode page 28 mayhelp
                          https://cdn.badcaps-static.com/pdfs/...26c3adb3b3.pdf
                          • Diah
                            • Feb 2013
                            • 6376
                            on his photo the stand by LED ON. the timer one / sleep on the left side.
                            it may one caused this that his 50 MB need to write the register of the PSU. as 50 one different .
                            by display, 5, volume down and power on. he can log at self diagnose to read the register ..
                            or he did change one data Value at time he rolling down to change size.
                            • hmendez86
                              • Jun 2015
                              • 344
                              • united states
                              When I command the tv the green ligth blinks once every time I press any command.....so what do i do
                              • hmendez86
                                • Jun 2015
                                • 344
                                • united states
                                I already try to disable from the menu but no luck....I went settings...eco and idle tv stanby I put it off and nothing happend...
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Maybe try a master reset if you can find how to do so.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    i dont see anything regarding master reset but the factory reset guide is here
                                    https://us.en.kb.sony.com/app/answer...9,62766,72628/
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      read this again please. if you was sure didn't change other data value at service menu, then the PSU register at NVM doesn't match. if you don't know how to write it i suggest you leave it as its and enjoy using it.
                                      • hmendez86
                                        • Jun 2015
                                        • 344
                                        • united states
                                        it may one caused this that his 50 MB need to write the register of the PSU. as 50 one different...
                                        How you mean the register....when I enter the service menu on the bottom said kdl50ex645 and serial number, but ther were darker and I couldnt move down and on the top of that it had panel size and the original said 50-50_ex645 and I moved to 60_60ex645 I just did that turn off the set and and back on and whala it work...just the red stanby ligth that is there...
                                        • Malva
                                          Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                                          by Malva
                                          I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                                          Mainboard model: EAX65684604
                                          PCB marking: EBT62954607
                                          SPI chip: Winbond W25X20CLNIG Problem description:
                                          Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                                          After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                                          • I bought another
                                          06-25-2025, 02:07 PM
                                        • Artefil
                                          HP officeJet 8012e ... A printer update will be installed to fix this problem
                                          by Artefil
                                          One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
                                          On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
                                          The screen displays the following message :
                                          "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
                                          But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
                                          Have you ever...
                                          09-28-2023, 05:11 PM
                                        • TheUser
                                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                          by TheUser
                                          Hello to everyone ,
                                          This is my first post here, and i would like to share with you a small story in case you can help me.
                                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                          02-10-2024, 02:07 PM
                                        • Catmouse
                                          HP EliteDesk 800 G4 - Orange LED behind Mainboard, not booting after BIOS Update
                                          by Catmouse
                                          I have 2 Elitedesk 800 G4 which have stopped working after a BIOS Update. It was doing the updates and instead of rebooting automatically it just stayed off and I was left with an orange LED being on behind the mainboard and no reaction at all when I hit the power button, it seems to be completely dead.
                                          Removing the battery, pressing and holding the yellow button on the MB didn't do anything either.
                                          Others have updated fine without any such issues.
                                          When googling I've found other people having the same issue with the orange LED being on and the PC also...
                                          10-29-2024, 04:27 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
