Sharp LC-42SB48UT-a no standby voltage
+ More Options
Posts
  • AcGeorgiegirl
    • Jun 2013
    • 202
    Re: Sharp LC-42SB48UT-a no standby voltage
    Originally posted by budm
    OK, so it cannot even maintain the regulated 5V output.
    I would try replacing C969 in the primary side and the 4 cap in the cold side by the connector that goes to the main board.
    I tested the ic...gave results above...replacing C969 resulted in no change. I'll go ahead with replacing the caps you suggest. Should I also use your earlier suggestion of replacing the IC, now that I know the cap it's connected with is ok, or first replace the 4 caps you've mentioned above?
    • AcGeorgiegirl
      • Jun 2013
      • 202
      Well, I've just read where I should ground to the filter cap's neg leg when I test the IC...and I did get a little bit different results(the 1st time I used the chassis to ground)....
      The 4th pin: .04
      All others: -.02 or -.03
      • jts1957
        • Dec 2008
        • 38
        #83
        Set uses BOTH Cold (metal chassis, tuner cover, etc.) AND Hot grounds (Pin #4 of the bridge rectifier or negative terminal of main filter cap, for example).
        • AcGeorgiegirl
          • Jun 2013
          • 202
          I realize that, thanks. I was wondering if I should have used a "hot" ground with the IC testing.
          • jts1957
            • Dec 2008
            • 38
            #85
            Yes
            • AcGeorgiegirl
              • Jun 2013
              • 202
              Well, I've replaced all the caps on the cold side, next to the connector(goes to main), and still no change in standby from 4.04v. That's a total of 5 caps, including the one suggested earlier(c969). The only component someone mentioned, I think is the TNY277 IC. I've been trying to find out if a similar IC, from a Samsung tv, I have on a spare powersupply is compatible, and thought I'd ask you guys. It's labeled: A6159 SK603 693C. It is the same size and same pin configuration.
              • jts1957
                • Dec 2008
                • 38
                #87
                No.
                • Iepreferred
                  • Jun 2015
                  I have same model tv doing the same thing with 4v standby did you ever get it fixed?
                  • radan
                    • Jun 2014
                    • 3
                    • trinidad
                    #89
                    ha a set like this with no stb voltage after changing tny277 voltage read 4v without main board connected .after connecting mainboard all voltages read correct and woked perfect
                    • TWB_Cool
                      • Aug 2020
                      Wait i have 4v standby, what should i do?
                      • jts1957
                        • Dec 2008
                        • 38
                        #91
                        Continue troubleshooting.
                        Service Lit. links earlier in this thread.
                        • x_orange90_x
                          Samsung UN55KU6300F no standby voltage
                          by x_orange90_x
                          I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                          Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                          05-21-2025, 09:59 PM
                        • Bad_IC
                          Philips TV 37pfl5604h/12 no standby voltage
                          by Bad_IC
                          I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                          These are the voltages in some pins of IC fsq510:
                          Vcc=18v
                          D=320v
                          Vstr=154v
                          Unfortunately, I couldn't find the schematic
                          What else could I check?
                          Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                          Thank you​...
                          11-08-2024, 01:07 PM
                        • brock-s
                          Asus GL503GE 3.3 standby voltage low
                          by brock-s
                          An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
                          Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
                          Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
                          07-13-2023, 03:43 PM
                        • tvguy12012012120
                          by tvguy12012012120
                          02-07-2025, 05:13 PM
                        • Ritchie_Uk
                          Sharp 32BC2K0 Service Manual of Fix Please?
                          by Ritchie_Uk
                          Hi Folks
                          I am searching for a Sharp 32BC2K0 Service Manual
                          Sharp 32BC2K0 << Could be an "O" as in Orange or a Zero
                          Fault - Coloured "Bars" very thin all across the screen.
                          I would like tho get the values for the 2 Resistors and I believe a Missing Capacitor.
                          I would Like a Service Manual, that has the component values, and locations, as the PCB isnt that clear as for designations
                          Is there such thing as a Boardview for this TV?
                          I will Post the Photos in a second
                          Stay Safe !...
                          09-05-2024, 06:35 AM
