Panel Cross Reference List
  • jjanssen7
    • Nov 2012
    • 252
    I'm wondering if there is any interest in keeping a list of panel replacements. For example, I've discovered that:
    LG 50LA6205, 50LN5750, 50LN5400, 50LN5700 have interchangeable panels.
    LG 47LN5750, 47LN5400, 47LN6205 have interchangeable panels.
    Sony KDL-50W800 and HiSense 50K23dgw have interchangeable panels.
    Sony KDL-48W600B and KDL-48R470B have interchangeable panels
    Samsung panels are sometimes interchangeable, even when they are one model year apart. EH/H for example. I've not kept track of those swaps, but I will now.
    I've used this to build one good TV out of two when I have one with a cracked screen and another with a faulty main board made out of unobtainium.
    Anybody else keeping a list like this?
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Panel Cross Reference List
    Keep it up! I love "frankenstiening" tvs. I will keep checking your findings for more .
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      When you say panels, are you talking about the actual screens themselves? If so, I'm with TVTimmy on this one! I think a list like that would be wonderful! I have a few screws that are good but the TVs aren't worth fixing. And I have some TVs where the boards are good but the screens are way to expensive to replace. I didn't ever think we could use different screens from different models. Thanks!
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • jjanssen7
        • Nov 2012
        • 252
        Yes, by interchangeable I mean they are the exact same LCD panels from the same factory. Switch panel only, not even t-conn or ribbons.
        I'll go over my notes 'cause I've done several Samsung swaps too. (Taking a panel from a good screen with bad LEDSs "dumb" TV and putting it into a smart TV with a cracked screen. Those certainly sell for more...
        • Spork Schivago
          • Mar 2012
          • 4734
          So if the screen works with another make / model television but the screen itself is actually a different LCD panel from another manufacturer or something, like talking a Phillips screen and replacing a broken Samsung screen with it, that wouldn't go on the list? Essentially, you just want to know which TVs have the same panels inside of them, right?
          • jjanssen7
            • Nov 2012
            • 252
            I've only swapped "like-for-like".
            Panels from same manufacturer but different models or when the the same panel is used by different makes because those TV companies source them from the same manufacturer in china. Sony & Hisense, for example. Vizio, Westinghouse, Insignia (local brand?) and RCA share some panels too. I'm looking into an Insignia-Vizio panel swap at the moment. I'll keep track of what I confirm but I'm wondering if others are doing this simple swap too?
            • Spork Schivago
              • Mar 2012
              • 4734
              I'll start paying attention and writing down what I find when I work on TVs and comparing what I found with other TVs. Thanks Jjanssen7.
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                Lg 50pm6700 and lg 50pa6500 have the same panel. I had a smashed new 50pm6700, bought a 50pa6500 with bad zsus and ysus in it.
                I combined the two to make a working 50pm6700.
                • jjanssen7
                  • Nov 2012
                  • 252
                  Got another one:
                  39" AU Panel from Hitachi LE39H217A (common edge-lit backlight burnout) is the same as the panel from RCA RLDEDV3988-A (and I suspect other RCA 39" models.)
                  • jjanssen7
                    • Nov 2012
                    • 252
                    Panel from UN40ES6100 with Tconn will work in Samsung UN40EH5300
                    • jjanssen7
                      • Nov 2012
                      • 252
                      LCD Panels from UN55J6200 is identical as UN55H6203
                      • Chungalin
                        • Jul 2014
                        • 422
                        • Spain
                        But this is no way a practical approach of keeping this information. You can't just add posts saying "this TV model has same panel than that other TV model". You have to keep a list of TV Brand - TV Model - Panel mfg / model. Could be an excel spreadsheet or ideally a database (as I'm doing it locally in MS Access).
                        I attach a Sony spreadsheet with TV key parts, including LCD panels. This was provided by Sony in year 2014. And a screenshot of my database, filtered by LCD panels. Here you can see that this way I can know that LC320WXN-SAB1 is installed on a Philips and a LG tv. Keeping this database is time consuming.
                        • jjanssen7
                          • Nov 2012
                          • 252
                          (Thanks for the Sony spreadsheet. That's an awesome resource!)
                          Actually, I was thinking of starting a list like you suggest, Chungalin. I wanted to see how many other people were looking for/interested in these swaps.
                          If my list is just made up of the stuff I discover then it will be a short list!
                          • jjanssen7
                            • Nov 2012
                            • 252
                            Panel from Samsung UN55ES8000 is the same as UN55ES7100
                            • jjanssen7
                              • Nov 2012
                              • 252
                              LCD Panel from Toshiba 58L4300 and 58L1350 is an exact match for Samsung UN58H5202
                              • jjanssen7
                                • Nov 2012
                                • 252
                                LCD Panel from Toshiba 46L5300 is same as Samsung Un46ES6820
                                • Chungalin
                                  • Jul 2014
                                  • 422
                                  • Spain
                                  For the same price, why don’t you say the panel maker and model for each coincidence?
                                  • jjanssen7
                                    • Nov 2012
                                    • 252
                                    I'll try to include that info in the future.
                                    • jjanssen7
                                      • Nov 2012
                                      • 252
                                      Samsung UN50F6800 LCD AUO T500HVN05.2 Panel is also found in Insignia NS-50D40SNA14
                                      • jjanssen7
                                        • Nov 2012
                                        • 252
                                        LG 49LF6300 with LC490EUE Chassis and V15 49FHD LCD panel contains the same LCD panel as Toshiba 49L420U with K490WDR1
                                        • eccerr0r
                                          Sell or Shim Solar panels?
                                          by eccerr0r
                                          Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                                          However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                                          So now what to do with these small panels?
                                          I could sell them...
                                          Or I could shim them....
                                          03-29-2025, 01:07 AM
                                        • connorcc2005
                                          Thermistor specs and cross reference
                                          by connorcc2005
                                          I'm getting some conflicting information and thought I'd toss it out to all of you for input.
                                          What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
                                          The physical diameter of the piece is 5.1mm measured with a caliper.
                                          Other than what you see in the pic, there is no other writing on the part.
                                          My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
                                          06-16-2022, 04:16 PM
                                        • raregtp
                                          Voltage regulator cross-reference
                                          by raregtp
                                          Hey all....hoping someone can help me with this. I have a couple voltage regulators I'm trying to cross but not having much luck.
                                          The first is:
                                          A1
                                          AS1117L-18
                                          B0640 25
                                          The second is:
                                          A1
                                          AS1117L-33
                                          B0640 28
                                          I know the AS stands for Alpha Semiconductor, and I think I've found a datasheet for the AS1117L-33, just can't find anything for the -18. Ultimately I'm looking to cross these over to parts that I can get now, as all I'm finding similar are AZ1117 regulators.
                                          If anyone can assist...
                                          03-15-2020, 11:12 PM
                                        • jasko_jacker
                                          cross reference tps51285a
                                          by jasko_jacker
                                          I try to substitute the RT6575B with TPS51285A,
                                          it seems to work but it is slightly warmer, the board does not start due to other problems so but not sure if replacement is possible...
                                          12-07-2021, 01:49 PM
                                        • speaktorob
                                          Reference Nvidia GTX 980 ti - looking for a new shroud
                                          by speaktorob
                                          So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
                                          Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
                                          03-22-2024, 03:00 AM
