Voltage regulator cross-reference
  • raregtp
    • Mar 2020
    • 9
    Hey all....hoping someone can help me with this. I have a couple voltage regulators I'm trying to cross but not having much luck.
    The first is:
    A1
    AS1117L-18
    B0640 25
    The second is:
    A1
    AS1117L-33
    B0640 28
    I know the AS stands for Alpha Semiconductor, and I think I've found a datasheet for the AS1117L-33, just can't find anything for the -18. Ultimately I'm looking to cross these over to parts that I can get now, as all I'm finding similar are AZ1117 regulators.
    If anyone can assist it would be much appreciated. And.....if you can tell me what they cross to, can you also share your source?? Thanks!
    Re: Voltage regulator cross-reference
    It is just a 1.8V fixed regulator.
    1117 series regulator.
    https://cdn.badcaps-static.com/pdfs/...5be0cd1d45.pdf
    • raregtp
      • Mar 2020
      • 9
      Thanks.....this is my first foray into replacing a voltage regulator. I've recapped tons of stuff but decided it's time to take thing further.
      So....the important part of the identification is the 1117 and the 18 (or 33) in the part number. Is there any type of a naming or part number standard when it comes to the rest of the letters I see when looking up 1117 series voltage regulators? To be fair, I'm an IT engineer and VERY used naming standards and "patterns"...so just looking to learn how it's done on electrical componants.
      Thanks for the quick answer!!
      • redwire
        • Dec 2010
        • 3912
        For semi's, look at prefix, root part number, and suffix. Last line is typically mfg plant and lot number or datecode. A logo can also help ID a part's mfgr.
        AS manufacturer Alpha Semi. This is AMS1117
        1117 root p/n and possibly package L (which I could not find an exact match) or L for low power etc.
        -18 fixed output 1.8V
        -33 fixed output 3.3V
        -50 fixed output 5.0V etc.
        These Vregs are a commodity item, jellybean common, so many companies make them in the gutters of china and it can be hard to find the original.
        • raregtp
          • Mar 2020
          • 9
          So is it fairly safe to say as long as I'm getting a 1117-18, and the pin/package looks the same and is the same size as what I'm replacing, that generally there won't be an issue?
            • 31159
            exactly.
            have this:
            https://www.aliexpress.com/item/32944697105.html
              • Jul 2011
              • 6058
              Originally posted by stj
              Thanks for posting this I need some of them regulators
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                Also seen 1117-ADJ for adjustable ones, plus some just marked 17-18 for the 1.8V fixed type
                Follow me on YouTube
                Learn Electronics Repair
                  The question to OP, are the regulators bad?
                  • redwire
                    • Dec 2010
                    • 3912
                    You've had luck with that seller? I never tried them.
                    The original (father) part is LM1117 with a max. Vin of 20V.
                    Note some variants have a lower input voltage rating IR is 7V, AMS is 15V. They are rarely run up high because of high heat generation.
                      • 31159
                      seller is good, i have that kit here now.
                      as for max input voltage, it actually depends on the output voltage.
                      the package can only drop so much.
                      • raregtp
                        • Mar 2020
                        • 9
                        Yea....working on a couple LP-2407 Gateway LCDs.....six of them to be exact. Four came back to life after recapping, the other two had obvious bad caps but didn't respond after recapping. With the help of this forum, went on to troubleshoot and identify my first bad regulators. One mainboard had two 1117s that were bad, a 18 and a 33. The other board had a completely different 1117 that was bad. That one in particular I had an easier time cross-referencing, probably because it was an AZ-1117 regulator.
                          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                          Based on Intersil's Robust Ripple Regulator...
                          11-05-2024, 03:24 PM
                        • playit
                          diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
                          by playit
                          hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
                          and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
                          for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
                          02-26-2025, 05:39 AM
                        • artvandalai
                          Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
                          by artvandalai
                          This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
                          The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
                          11-05-2024, 07:38 AM
                        • Long AMD
                          Acer AL1916W - Two seconds to black - Voltage regulator problem?
                          by Long AMD
                          Hello all. Excellent forum you have here - it has already been a great help to me. I am posting the details of my situation before I go and start buying parts to see what suggestions the great minds here may have on diagnostics or otherwise.
                          I have an Acer AL1916W monitor which has recently failed in the following way: the screen comes on at power on, but after a couple seconds the screen goes black. Using a flashlight, I can easily verify the LCD is fine but there is simply no backlight.
                          The power supply board is of the type ILPI-025 Rev C (Date of manufacture was...
                          09-13-2020, 05:59 PM
                        • shakib200
                          Ram regulator misbehaving DDR3 VTT voltage Tps 51216
                          by shakib200
                          The ram regulator produces VTT voltage of 0.65V and the display comes. When we restart the laptop the VTT voltage becomes 0.75 and no display.[Used same ddr3l ram].
                          Also, it becomes 1.35 V on the ram coil and all are okay but after restarting Voltage becomes 1.5V with no display.
                          03-16-2024, 11:33 AM
