RCA 55" LED55G55R120Q, led driver comes up and shuts right down
  • football0062
    • Dec 2011
    • 98
    have a LED55G55R120Q the LED driver is built into the power supply, uses 2 sets of 6 row LED strips, 9 leds per strip. so 54 leds per channel. running at 179volts peak. the issue is when i trigger the backlight on, even manually by supplying 4v to the BLon and Adj the leds light and fall right on its face.
    replaced with an ebay "supposed working board"
    tested all LEDs(working) tested by running to a board from another set i had using a 174volt source.
    replaced main board(reason i tried this was because while messing around with the power supply i can get the led driver to stay on if i apply 4v to the adj and bLon rapidly i will get lucky and it will just stay on. new board made no difference.
    board is a RE46HQ1640
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: RCA 55" LED55G55R120Q, led driver comes up and shuts right down
    It may just be the camera angle but one of the solder joints on the led output connector looks bad. Circled red.
    • football0062
      • Dec 2011
      • 98
      thats just leftover solder from when i connected both grounds to eachother, made no difference, still just blinked on and right back off
      • football0062
        • Dec 2011
        • 98
        also i have replaced these caps, board is full of the cheap capXon and Aishi polarized caps
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          So you can verify that all the leds work by connecting them to another supply. If that's the case then you may have a Led driver fault. What IC controls the LEDS?
          • football0062
            • Dec 2011
            • 98
            there is no led controller, its all zener diodes, resistors and caps.
            and yes the leds work perfectly every one lit and stays lit using a board from another set (part number is 890-pf0-5501)
            also i just swapped the driver ICs on the primary side, made no difference, also if i short the photocoupler in the picture on the primary side it does the same thing, leds light up and falls. it actually does this in 2 quick pulses, either way i turn it on, with main board or by shorting the photocoupler
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Looks like it going to be a hard slog of checking each and every component with your meter to see if you can spot a problem. Without a schematic I can't suggest any other option.
                OOPS! wrong board wrong thread!
                • football0062
                  • Dec 2011
                  • 98
                  ok so i just noticed something here, on my primary im only getting 160V DC usually i at least get 168VDC in a standby state, but i am switching this power supply on using the PSon making it high with a 4v input. when i turn the leds on it drops to 150s. on this power supply doesnt the transformer L102 which i have circled, up the voltage to 350-380 range? main cap is rated at 450V.
                    The inductor is for the PFC Voltage booster, so when PS-ON is present the DCV between the two legs of the main cap should be 380~400VDC range.
                    • football0062
                      • Dec 2011
                      • 98
                      yea and its 160v, think that is where my problem is
                        U101 is the PFC Controller IC.
                        • football0062
                          • Dec 2011
                          • 98
                          ok so this is what happens, i started from the beginning to see what was going on.
                          using main board
                          -turn power on, 350v at main cap, leds flash, then voltage drops to 158v on main cap.
                          -will not come back up unless i unplug and plug it back in
                          manually applying 4v to ps on, then 4v to BLon
                          -cap stays at 350V the whole time 4v is supplied to pson
                          -when 4v is applied to BLon, leds flash. cannot get voltage back up without unplugging and plugging back in.
                          Now if i disconnect the LEDs from the power supply(i know bad idea) i get 228V output on my secondary and it stays constant. that doesnt add up either because there is only 54 leds. each would have to make up for 4.222....volts. i know there is no load though. thoughts?
                          • football0062
                            • Dec 2011
                            • 98
                            ok so heres the update, the led driver still will not do anything more than power up those 2 sets off 54 leds for more than a hot second, but it will power on and stay on at 180v to 2 sets of 56leds each side of a strip i had laying around out of a samsung.
                            also i hooked the other power supply up(890-pf0-5501) that i was using to test the leds on this rca and it still lights every single led up. what the fockk pics attached
                            (the bar has 56 leds per half in series.)
                            (the strips have 9 leds in series with 6 strips per side in series, totaling 54 leds)
                            any thoughts as to what might be going on?
                            • football0062
                              • Dec 2011
                              • 98
                              **THE FIX**(i hope)
                              i loaded up a completely different set of leds and soldered the strips into series. 54 on one line and 56 on the other. ran perfect. so dropped one out and put in 1 set from the TV, worked perfectly, so i swapped to the other set in the tv and that side worked perfectly as well. so i put both sides together for the fun of it and bam! fired right up. only thing that changes was the crimping on the cables got cut off and stripped to bare wire. so soldered wires straight to board and its been running perfectly.... strange because i remember even checking resistance from the LED driver to the boards and they all looked fine in the beginning.
                              • Deaddog2017
                                • May 2017
                                Working on the same problem ,same set, LED55g55r120q. I get the quick flash with some vertical lines. Looks like PS goes into shutdown. Changed out PS but same problem. No voltage on LED + and - outputs from PS.
                                Do you know what the voltage should be?
                                • stuffinabox
                                  • Dec 2017
                                  • 12
                                  same set close to same issue when i turn on takes a few minutes noted that the 6v on power supply comes up at 4 initially. thinking failing power circuit. some of the time i can power off and back on and come right up.
                                  • ndriana
                                    • Sep 2019
                                    • 4
                                    • Bermuda
                                    So, in the, you have no clues why it didn't work, and why it did work?
                                    I'm still on the part where why it doesn't work.
                                    • osrex
                                      LED DRIVER KEEPS DYING
                                      by osrex
                                      Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                      i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                      i have no datasheet at all for the LED lights, all i have is its length.
                                      long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                      as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                      05-05-2025, 03:36 PM
                                    • howardc64
                                      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                      by howardc64
                                      Problem
                                      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                      Model & Board Pics
                                      Conflicting Spec
                                      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                      https://www.shopjimmy.com/vizio-gj-2k1...
                                      10-10-2024, 01:16 PM
                                    • charif
                                      Audio Driver for Thomson P14C4BK128
                                      by charif
                                      Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                                      I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                                      The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                                      Here are the details:
                                      • Model: Thomson P14C4BK128
                                      • Operating System: Windows 10 64-bit
                                      If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                                      Thanks in advance for your help!
                                      04-30-2025, 05:41 PM
                                    • bohaboha
                                      how to install gl usb2.0 uvc camera device driver on windows 10
                                      by bohaboha
                                      Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                                      but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                                      any help?
                                      01-26-2025, 08:33 PM
                                    • Daveleone
                                      UN55D6900 BN44-00428B partial led driver circuit failure
                                      by Daveleone
                                      Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
                                      I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
                                      07-23-2021, 06:31 PM
