Hitachi 22LD3750DC TV repair, white screen, problem in AUO T220SW01-V0 panel
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    This TV shows all white screen, sound OK.
    Panel is an AUO T220SW01 V0, 22", 4xCCFL. I expected open T-CON power fuse, but no luck this time. Fuse is OK, and there’re 5V at test-point. Also measured 3.3V and other voltages.
    I see that after a while, some bluish smudges appear slowly on screen.
    I’ve tried to connect a ChiMei M190A1-L02 (that have the same LVDS connector) and it works, so it seems a panel problem, as expected.
    After some observation, I see that there’re about 5-6 horizontal lines of active pixels on top of screen. They contain no valid image. Seem like alternating white and black pixels.
    Anything I can do before giving up?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Hitachi 22LD3750DC TV repair, white screen, problem in AUO T220SW01-V0 panel
    Sounds like a failed tab bond driver to me. I have had this before on similar screens.
    • Chungalin
      • Jul 2014
      • 422
      • Spain
      Thanks Reecey. I’ve parked this repair because I see no chances of success.
      • harp
        White screen repairs
        by harp
        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
        05-13-2024, 03:43 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • thesharpfella
        Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
        by thesharpfella
        Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
        07-23-2024, 10:37 AM
      • EazyBone
        Sharp LC-65Q620U White Screen
        by EazyBone
        Another TV topic!!
        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
        08-21-2024, 12:56 PM
      • hcinne
        Dell G15 ryzen edition black screen 2 amber 1 white
        by hcinne
        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
        07-23-2024, 07:56 AM
