Sanyo LCDTV FVM5082 - Powers on, Video displayed, but no backlights.
  • fuxxy
    • 318
    Sanyo LCD TV
    Model: FVM5082
    Power Board:
    Model: B109-J01
    Digital Board:
    Model: Z6WF#316A-1599
    Analog Board:
    Model: Z6WE#411B-0629
    PCB30007
    I found this TV in the trash by the road. It will power on, and the power LED turns green. The backlights will not turn on. I get display on the LCD, just simply no backlight.
    This seems like an odd configuration to me. The backlight inverters are located behind the LCD panel, on a daughterboard that the CCFL's connect directly to. A 14 pin cable connects the daughterboard to the power supply board.
    I'm in the process of following the flowchart in the service manual one more time. It's been a couple months since I've messed with this TV and I want to be sure of the information I'm posting. Last time, I remember the flowchart diagnosis of "Replace Analog board".
    2 Questions so far:
    It appears that this design will allow the other backlights to run, even if one is bad. Do you guys agree?
    Is there a way to force the backlights to turn on? (To diagnose which CCFL's are bad, if any.)
  • fuxxy
    • 318
    Re: Sanyo LCDTV FVM5082 - Powers on, Video displayed, but no backlights.
    Service Manual
    • fuxxy
      • 318
      Flowchart Process:
      Power LED turns ON, but LCD backlight is not ON or on ly turns ON and then OFF.
      For analog signal board: Is the "BL_SW" voltage (3.3V) Supplied from "K8B Pin13"?
      - I get 3.1V from pin 13 of Analog Board connector K8B.
      For Power board: Is the 0V supplied from "CN3 Pin10" during LED on?
      - I get 0.5V from Pin 10 of Power Board connector CN3.
      Panel is broken. Replace "Panel".
      The LCD display itself is not bad. I'm assuming the "Panel" is a preassembled unit containing the Backlights, inverter, and LCD.
        You have correct signal, the way to look at it is like this:
        If the inverter circuit is good but you have a couple of bad lamps, then the inverter circuit should kick on and try to fire up the lamps for it to know if it encounter bad lamps or not, so the at least some of the lamp should at least come on before the protection circuit kicks in.
        Since you did not even see the backlights flash on for seconds then we need to verify that the Inverter transformers driver circuit (which is on the power supply/Inverter transformer driver combo board) is OK or not.
        So first of all, the red round fuse FL1 for the Inverter transformer is OK?
        • fuxxy
          • 318
          I replaced FL1 when I last opened this set a few months ago. I don't remember testing it after putting it back together and it still not working.
          FL1 is blown.
          • fuxxy
            • 318
            I think I know your next question, so I'll go ahead and answer it.
            Fuse FL1 feeds MOSFETS Q|1 and Q|2. Both mosfets source-to-drain resistance is zero(shorted).
              Well, you found the problem.
              • fuxxy
                • 318
                I replaced MOSFETs Q|1 and Q|2 with what appears to be a replacement, even if the case size is different. Originals are Farnell 12N50F, and I replaced them with 2SK3522.
                The replacement fuse popped as soon as I plugged in the mains power.
                • fuxxy
                  • 318
                  What are the specs I should be concerned with when sourcing a replacement part?
                  To me, the replacements I found seem compatible, but now I'm not so sure..
                  Original: MagnaChip MDP12N50F
                    The input capacitance of the 2SK (2280pf typ.) is much higher than the original 12n50 is 1010pf, this may cause cross conduction.
                    I would use the original MOSFETs and also check all the resistors/diodes connected to the GATE of those MOSFETs for damages.
                    • fuxxy
                      • 318
                      Tested the resistors and diodes attached to the gate seen in this pic, all appear within tolerance.
                      I'll keep searching through my parts bin for compatible MOSFETs, and I'll order if I can't find them. It appears an NTE2928 is almost identical as well.
                      D|3 0.547v
                      R|20 - 10K Ohms
                      R|16 - 47 Ohms
                      R|17 - 22 Ohms
                      D|6 - 0.548v
                      R|35 - 10K Ohms
                      R|28 - 47 Ohms
                      R|33 - 22 Ohms
                      C|22 - I don't have a capacitance meter to test
                      R|32 - 51 Ohms
                      RJ18 - Shorted (Jumper?)
                        Those two snubber caps C134, C135 are good with no leakage resistance?
                        • fuxxy
                          • 318
                          Both capacitors, when removed from the board, read "OL" resistance (infinite)
                          • fharris1977
                            Sanyo DP65E34 Backlights off after a 1-2 sec
                            by fharris1977
                            Hello. I have a Sanyo TV that had no backlights at first. I changed CS9 off the power supply and now the backlights will come on for a second or 2 and go right back off. I can see the image if I shine a flashlight in the screen. Anyone familiar with this particular model and problem, your help would be greatly appreciated. Thanks in advance....
                            03-14-2023, 01:13 PM
                          • djmka
                            Philips 65PUS6554/12 - only powers on if you prime backlights first
                            by djmka
                            Hi everyone.
                            I have a problem that I would appreciate some expert advice on.
                            I have a 65” Philips television which powers on, has sound but but no picture. Usually this would lead me to believe an open circuit was present on the backlights. However, if I disconnect the mains power cable to the television and test the power cable going to the backlights using a LED tester, no open circuits are present. If I reconnect the backlight cable to the power board and replace the mains power cord to the tv the device fires up perfectly and displays a beautiful picture. It's almost as though...
                            08-31-2022, 03:12 AM
                          • nosaj
                            Samsung QN82Q70RA powers on then powers off
                            by nosaj
                            I have a samsung QN82Q70RA powers on then powers off. Using some info on the interwebs. I disconnected main board from power supply and backlight shows blue and stays on indicating power supply is good. So next I unplugged one on the lvds cables that connects to screen( I think other side goes to tcon board?) i can get a blue screen and if I press the picture button on the remote i get rain sounds and birds chirping. A lot of videos suggest using kaptan tape to cover the clock signals, but I've been unsucessful there.
                            So I thought I'd just quit messing around and come to the best site...
                            11-07-2025, 04:58 PM
                          • max789
                            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                            by max789
                            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                            I made the following tests:
                            1. Disconnected the main board from Power Board = backlight works.
                            2. Connected the main board and disconnected the T-Con = backlights does not work.
                            So I ordered a main board from Ebay also BN41-02156A but from...
                            01-18-2024, 06:56 AM
                          • bpcannan
                            VIZIO M557-G0: Backlights or ???
                            by bpcannan
                            'Morning,
                            I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                            Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                            I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                            I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                            10-29-2023, 06:36 AM
