Sanyo DP65E34 Backlights off after a 1-2 sec
  • fharris1977
    • May 2017
    • 132
    Hello. I have a Sanyo TV that had no backlights at first. I changed CS9 off the power supply and now the backlights will come on for a second or 2 and go right back off. I can see the image if I shine a flashlight in the screen. Anyone familiar with this particular model and problem, your help would be greatly appreciated. Thanks in advance.
    • 12306
    • U.S.
    Re: Sanyo DP65E34 Backlights off after a 1-2 sec
    Prolly bad led/s or bad connection in the backlights.
    • signal.quest
      Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
      by signal.quest
      I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
      I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
      09-30-2024, 11:21 PM
    • frannyjunk
      Hisense 40H4F no backlight but turns off after splash screen
      by frannyjunk
      So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
      TIA.
      09-24-2025, 10:59 AM
    • bpcannan
      VIZIO M557-G0: Backlights or ???
      by bpcannan
      'Morning,
      I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
      Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
      I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
      I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
      10-29-2023, 06:36 AM
    • jesterace
      Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
      by jesterace
      Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
      However, I am in a dilemma.
      I tested the backlight outputs with the lights disconnected...
      10-20-2024, 10:15 AM
    • x_orange90_x
      Sony KD-75X750H no backlights
      by x_orange90_x
      I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
      Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
      07-16-2025, 07:49 PM
