LG 42LE4500 pink line
  • sordids999
    • May 2013
    • 2161
    • uk
    hello
    just wondering if anyone has seen this before and is it fixable im still thinking its the panel at fault ?
    not got the tv yet so any help would be appreciated
    thanks
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 42LE4500 pink line
    Panel failure IMO.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
        Panel failure, this model is prone to water damage.
        • sordids999
          • May 2013
          • 2161
          • uk
          hmmmm
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Haha just messing deffo panel though
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              So water spawns over the tabbond driver ?
              • sordids999
                • May 2013
                • 2161
                • uk
                And thanks for the reply`s
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  No worries bud
                    Water spills usually, tab drivers have no protection. Seen it before on 37LE4500 with nearly identical symptom, except it was one white bar on left half and the other half was working ok.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Yeah I was messing again Tom, you said "prone" to it but its only if the owners do it not common though
                        Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                        This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                        09-06-2024, 09:30 PM
                      • jimjoe123
                        LCD TV Green/Pink screen problem
                        by jimjoe123
                        I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                        Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                        Then each time...
                        02-23-2020, 01:29 AM
                      • cubytus
                        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                        by cubytus
                        Hi to all,
                        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                        01-10-2024, 01:26 AM
                      • otaku_nut
                        Vizio E701i-A3 fixed but now has red vertical line
                        by otaku_nut
                        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                        08-19-2025, 06:11 PM
                      • TrueSword88
                        Kogan - KALED65XU9220STB - Blue Vertical Line
                        by TrueSword88
                        Hi all.
                        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                        The line just happens to coincide with the end of COF and start of the next COF (attached).
                        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                        Hoping to fix...
                        05-05-2023, 04:28 PM
