Bush BMK40 no picture/sound
  • london-freddie
    • May 2015
    • 472
    Hi
    Here I am again with my latest project just bought a dead Bush BMK40 LED TV for a tenner easy problem I thought !!!!!!!!!
    Opened it up NO board fitted no wonder it was dead
    Boards seem to be like rocking horse s*** for this tv but found one on ebay for 15 all i had to go on was bush BMK40
    Got the board a TP.SIS231.P83, only board I could find
    Fitted the board and not working
    First problem the LVDS connector on the board has two rows of 20 pins, connector on the TV has two rows of 15 pins so not sure which pins to use, connector seems to go on any combination of the pins.
    However I fitted the connector as in the picture.
    When TV is plugged in red led shows on the front, when power switch is pressed red light turns green and backlights come on but no sound on picture
    Any ideas lcd looks good
  • london-freddie
    • May 2015
    • 472
    Re: Bush BMK40 no picture/sound
    Bush BMK40 pics
    • london-freddie
      • May 2015
      • 472
      No picture or sound
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Check if you have any voltage on the TCON fuse.
        • london-freddie
          • May 2015
          • 472
          give me couple of mins
          • london-freddie
            • May 2015
            • 472
            No voltage at TCON fuse
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I would think the red wires on the LVDS cable connect to the fuse on the Tcon board but would need to be verified.
              • london-freddie
                • May 2015
                • 472
                have just moved the LVDS connection down to the bottom ie: the red cables at pin 1 still no voltage at TCON fuse
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  You need to use your meter set to ohms to find if the red wires go to the Tcon fuse.
                  Then find out which pin(s) on the main board LVDS connector (disconnected) has the supply voltage.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    An ebay picture shows the LVDS connector connected differently on the main board.
                    http://www.ebay.co.uk/itm/BUSH-LED-M...p2047675.l2557
                    • london-freddie
                      • May 2015
                      • 472
                      ok you are right it is the red wire on the LVDS cable that goes to the TCON fuse.
                      The fuse on the TCON is marked as 125V / 3A
                      Have checked all pins on the mainboard connector no voltage at the pins connected to the red cable, several of the pins have small voltages ie 3.6v 2.5v 1.5v but nothing on the pins that would connect to the red wires to the tcon if that makes sense
                      • london-freddie
                        • May 2015
                        • 472
                        yes thanks for that, that is now how I have got it connected Red to pin 1 at the bottom
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Are all the voltages up and running on the power supply?
                          • flocko
                            • Nov 2012
                            • 1121
                            I would think the board is not compatible,these combine boards are fitted to loads of set running lots of oddball LCD panels.TP.SIS231.P83 is just the board number the white bar code sticker number is the part number and has to be matched to the correct LCD panel used in the set. and as you bought the set with no boards fitted, the fitting of a board from any bush 40" set will be pot luck at best
                            • london-freddie
                              • May 2015
                              • 472
                              Trying to find what screen is fitted to this tv, Are you thinking I am wasting my time with this
                              • flocko
                                • Nov 2012
                                • 1121
                                I think panel will be LSC400HM06 as this runs a T.Con.not sure as to what main board number you need some do not run a T.con at all just a LCD driver on tabs to the screen.unless you can find a board that you know comes from a BMK40 then you will have a job on your hands.will need lots checking on the net to find a match
                                • london-freddie
                                  • May 2015
                                  • 472
                                  ok that makes sense, this panel has the driver board on the tabs, but cant find any reference anywhere as to what panel it is
                                  • london-freddie
                                    • May 2015
                                    • 472
                                    driver board or tcon as some sellers are calling fitted is Y13_MB7S60TS4LV0.3 but still not sure what panel this is, did find a picture of a LSC400HM06 with this driver fitted
                                    • london-freddie
                                      • May 2015
                                      • 472
                                      driver tab pic on ebay mine does not have the white sticker on
                                      • cheeky2
                                        • Dec 2012
                                        • 337
                                        Did you ever manage to sort out this TV? I ask as I have one that I am pretty sure is the flash ic that has corrupted. I am after the binary of the flash ic if you have made a copy of it?
                                        Thanks Anthony
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
