LG 50PK790 No Image No Sound
    Re: LG 50PK790 No Image No Sound
    Phosphor is not a gas and it does not act like one for a start, Xenon, neon, argon etc are in the panel they are gases. No way in hell do they overload or overheat either thats Bs you made up. The only way a Pdp can fail is if its cracked or the Panel electrodes short which almost never happens.
    Also the other stuff about X/X and Ysus boards you said doesn't make sense Im not even going to bother justifying that. Dont pretend to be a Pro if you know nothing, you will be shown up very fast on here.
      Originally posted by RavenHerald View Post
      I hadn't even considered that it would be the solder, just presumed it would be one of the components! Thank you I will see if I can get it working, otherwise will be in touch if you did want to take it.
      Awesome keep us updated
        Originally posted by charis View Post
        You are trash!
        i try to talk simple all this gas inside a plasma is acting like a Phosphore.
        In the instustry is a common language from the past every technician know this.
        I do this for a living if you guys thinks you smart i said all the common problems on lg plasma in the above post.
        Is the greek back? His brother in law perhaps? Another fucktard up for banning,that's for sure. Stop right there greek,your not smart,not at all.
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
          Martino I love the way you put things
            Tried the oven trick and it works completely fine -all fixed and thank you so so much!
            I really appreciate the help, so glad it was fixable and now I can continue wandering the wastelands in Fallout!
              Awesomeness, my advise would be add a small fan over the Cpu heatsink. Should keep it chugging a little longer
                Thank you I will get that sorted as well, so happy it's alive and would like to keep it that way for as long as possible.
                  Hopefully, too bad Lg cheeped out on the Cpu cooling could of lasted longer
                    All you Plasma sets in Greece....
                    Be Afraid--Very afraid!-- There's a madcap wannabe 'tech' in your country!
                    TELEFIX
